Changing 92 4.0 timing cover seal
Old Oct 6, 2014 | 12:37 PM
1998Ranger25L153CID's Avatar
1998Ranger25L153CID
What has to be removed to change the front seal on a 92 4.0? Do you have to remove the cover of can it be changed with the cover on? I checked labor hours and is 1.3. Is 100.00 to change reasonable? Do I need the sleeve n seal or just the seal?
Old Oct 6, 2014 | 02:09 PM
Hank85713's Avatar
Hank85713
go over to autozone.com set up an account and use their repair guides. you will need to remove the fan, the belt the lower crank pully at a minimum, more than likely the radiator. I dont think they have a sleeve for the front just the rear main. I could be wrong, so look up the part and then click on repair help.
supercab78
Jan 10, 2008 08:20 PM
gtex
Sep 15, 2003 05:33 PM
ranger429
Aug 3, 2003 04:13 PM
