Stolen 1973 Ford bronco
Reward offered for the information leading to the return of 1973 Ford Bronco.
Stolen on July 22nd 2014 (between 6:30am and 7:00pm) from NM railrunner station (Los Ranchos Journal Center)
White body with faded blue trim, faded blue full hardtop. Fiberglass hood scoop,
15x8 black spoke rims(cheap wagon wheel style), Baja(protofab) front bumper. Stock rear bumper. Ford decal right rear window.
Lic # 209CRK
Vin# U15GLQ52221
Cut out rocker panels.
Stock 302 with MotorCraft 2bbl carb on Edelbrock performer intake with phenolic adapter, Duraspark distributor with GM module. Late model mustang aluminum valve covers.
Custom upper radiator mount using unistrut
Custom single exhaust with exit behind rear tire.
Ford c4, w/B&M deep pan, Dana 20 t shift.
Transmission cooler under driverside rocker panel.
Duffs power steering(scout box) GM pump.
Single 21 gallon gas tank by BC Broncos.
Disk brake Dana 44 (gm parts) and Warn Hubs.
Rear ARB 9in w/drums..31 spline with conversion bearing for use with small bearing axle housing.
3.5 lift. Wild Horses coils/spring packs. Extended Radius Arms (Fabritech from Jeffs bronco Graveyard)
Rancho RS9000's
32 x 11.50 BFGoodrich Allterrains.
Painted silver/gray rear driveshaft.
Stich(cartoon) decal on rear driver side window.
Stepridge studios decal on lower left back window
Skate board wheel driver side window crank
Last seen in this parking space:
https://www.google.com/maps/@35.1755...QLa1CJgoBA!2e0
Stolen Bronco
I've owned it for 22yrs so the sentimental value is huge. Endless source of fun and tinkering..
I was using this bronco as a daily driver because of its rock solid dependability.
Still have some hope...
Thanks for your time.
J Romero
