Fog Lights + High Beam Mod
Old Aug 11, 2014 | 08:13 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Has anyone attempted and succeeded or failed at getting their fog lights to stay on when the high beams are on yet?
Old Aug 11, 2014 | 09:58 PM
bridge's Avatar
bridge
Sick 'n Tired
Haven't tried yet, don't use the hi beams that much. I had an '01 Expedition where this was achieved by removing the switch and shaving off part of the grooves underneath.
Old Aug 12, 2014 | 02:05 AM
ngng's Avatar
ngng
I have my fogs wired to one of my upfitter switches, problem solved.
Old Aug 12, 2014 | 02:31 AM
Byooty's Avatar
Byooty
Same but different.
I fitted some aftermarket head lights with dual lights on both sides, the headlight would go off if switched to hi beam, and just leave the hi beam on.
I put some diodes so that the headlights received power when on hi beam but the hi beam stays off on low beam.........magic.......
Old Aug 12, 2014 | 06:50 AM
System's Avatar
System
Prolocutor
Search for "bright box" or "brite box." They make them plug and play and are fairly inexpensive.
Old Aug 12, 2014 | 08:39 AM
TRENT310's Avatar
TRENT310
The relay is marked "non-serviceable" in the wiring diagram, so it's not socketed. You have to bypass the BCM with an external relay. By doing that, you do loose the "battery drain protection" feature however.
Old Aug 12, 2014 | 11:31 AM
robinsonpowerstroke
I just looked them up and they only make boxes for 2010 and older.
Old Aug 12, 2014 | 11:34 AM
robinsonpowerstroke
Darn, I was hoping it was going to be as easy as going behind the head light switch and putting in a diode jumper wire.
Old Aug 12, 2014 | 11:46 AM
720Deere's Avatar
720Deere
At least the 2011-2012 trucks still use the same Brite Box as the 2008-2010. A lot of companies don't list it, but the Brite Box website does and several guys on this forum have used them successfully.
Old Aug 12, 2014 | 12:02 PM
robinsonpowerstroke
10-4 thank you
Old Aug 12, 2014 | 01:21 PM
System's Avatar
System
Prolocutor
They just haven't updated their website. 2011 takes part number F8.FLC.5P. Costs about 250. Keeps fogs, highs, and lows all on at once...
Old Aug 12, 2014 | 01:48 PM
720Deere's Avatar
720Deere
Or for about $129 they have the single box model that only keeps the fogs on with the high beams. I think you just take the "P" off the part number for that one.
Old Aug 12, 2014 | 03:31 PM
robinsonpowerstroke
Awesome! Now does this disable the head light time out feature?
Now where do you get them? Innovadd themselves? I can't seem to find them on Amazon.
Old Aug 12, 2014 | 03:37 PM
720Deere's Avatar
720Deere
http://www.amazon.com/s/ref=nb_sb_no...0box%208.FLC.5
Amazon.com: brite box 8.FLC.5b
When you use the B model that uses the low beam lights along with the high beam and the fogs, the "additional" lights are being powered directly from the battery. I don't know for sure, but I am assuming that the BCM is not able to realize that the headlights are on and will not automatically turn them off. If you walk away from your truck with the low/high beam and fogs all on, you have bigger problems than a dead battery! LOL
Old Aug 12, 2014 | 03:43 PM
robinsonpowerstroke
http://www.amazon.com/s/ref=nb_sb_no...0box%208.FLC.5 Amazon.com: brite box 8.FLC.5b When you use the B model that uses the low beam lights along with the high beam and the fogs, the "additional" lights are being powered directly from the battery. I don't know for sure, but I am assuming that the BCM is not able to realize that the headlights are on and will not automatically turn them off. If you walk away from your truck with the low/high beam and fogs all on, you have bigger problems than a dead battery! LOL
Very true! Awesome thanks man!
