new 65" f1oo
I had the ring and pinion go bad on my '65 F-100. When the banjo was m.t., I cleaned the whole thing out with gas. let it dry out good for a couple days. Then took my torch and burned a hole in the banjo bottom. Cleaned up the slag with a grinder and then welded a 2,000# threaded 90deg elbow over the new hole. So that I can drain the oil every 50,000 miles. The banjo is not thick enough (material) to stand any threads. This is why I welded a forged grade fitting (threaded) on the bottom. This has worked well for me. I used a 3/32, 7018 welding rod if you were wondering. Don't use any 60's series welding rod. There is not enough carbon in that series. The forged fittings need the higher carbon out of position rod. The weld will crack if a 60 series rod is used. Hope this helps, Cheers,
Pete
$5.97
<form id="addtoForm" action="" method="post"><input name="quantity" id="quantity" type="text" size="1" maxlength="2" value="1">
<fieldset><input name="addtocart" id="addtocart" type="image" alt="Click here to add SUM-G1380 to your shopping cart." src="http://www.summitracing.com/images/button-add-cart.gif"> <input name="sku" type="hidden" value="SUM-G1380">
</fieldset></form>
(2) Review This Product
Drain Plug, 1/2 in.-20 Outside Threads, 1/8 in. NPT Plug, Kit
Estimated Ship Date: Today Would you rather pick it up? Select Location
View Similar Products
Summit Racing® Drain Plug KitsPart Type:Drain Plug Kits
Brand:Summit Racing
Manufacturer's Part Number:SUM-G1380
Product Line:Summit Racing® Drain Plug Kits
Summit Racing Part Number:SUM-G1380
Drain Plug Thread Size:1/2-20 in.
Drain Plug Material:Steel
Includes Pipe Plug Port:Yes
Pipe Plug Port Thread Size:1/8 in. NPT
Quantity:Sold as a kit.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
These Summit® universal drain plug kits can be added to transmission pans, differential covers, or anywhere you need to change fluids, but don't have a factory drain plug. Just drill a 1/2 in. hole and mount one of these plugs into the pan.
Warranty
..... another thing is the timing chain gears on these 352's have nylon on them (factory noise reduction) and after sitting or long use they break apart and fill the pan with little yellow chunks that plug and fill your tranny pan and can lock up your oil pump see how some of the yellow is missing in this pic?
1) Ford 9 inch: No inspection cover, no Limited Slip, no drain plug.
2) Spicer/Dana 44: Inspection Cover, Limited Slip, 358048-S Drain Plug-3/4" -14.
3) Spicer/Dana 60.2: Inspection Cover, Limited Slip, 358048-S Drain Plug-3/4" -14.
OP says his F100's rear axle has no drain plug, so it's a Ford 9 inch.
and let the oil fly! Gives you the opportunity to inspect all the internals. And will only cost you a gasket. And lube.
