New guy working on a F3
Old May 27, 2014 | 07:47 AM
VCF3's Avatar
VCF3
Please don't flame me, I have searched the site first and am still not clear on this. I have a 1951 F3 that I'm restoring, mild hot rod, shop truck sort of thing. Can I put F1 rear springs on this truck to soften it up? I looked at specs for rear springs and the eye to eye is within 1/2" but the spring is 2" wide on F1 and 2 1/4" on f3. So my question is I guess, can I fit the F1 perches on the F3 frame? Anyone do this? Thanks in advance, sorry if I'm bringing up old topic.
Old May 27, 2014 | 08:10 AM
38 coupe's Avatar
38 coupe
Welcome!
I'm not sure if the springs will interchange. Most people take the leaf pack apart, remove some of the leaves, clean things up, and put it back together. You may need shorter u-bolts to bolt it back together afterward but that is more cost effective (polite way of saying cheaper) than new springs and hangers.
Not much flaming goes on in this forum. We are generally pretty laid back and don't like shouting matches. We do like pictures. Someone will probably be along soon and give a tutorial on how to post to this forum (usually involves photobucket or other off-site photo hosting place).
Old May 27, 2014 | 08:16 AM
aussiecowboy's Avatar
aussiecowboy
As stated, just remove every second leaf, much easier than installing different perches. Great to see another F3 around, there isn't that many of us.
Old May 27, 2014 | 08:26 AM
VCF3's Avatar
VCF3
Awesome info thanks. I'll pull a couple springs, I'm Sure same can be done with front if I want it to sit down a little? I plan on doing the disc brake conversion in front. Going to run 5 x 5/12 wheels. Tried posting pics on my page don't know if it worked. Plan on rebuilding the flattie, doing a 12 volt conversion, interior work and blast and prime truck to get on the road by next summer.
Old May 27, 2014 | 08:31 AM
VCF3's Avatar
VCF3
I mean to say I'm going to run wheels with 5 lug to eliminate widow makers. Don't know exact size yet as I have a lot of fender to fill
Old May 27, 2014 | 08:35 AM
38 coupe's Avatar
38 coupe
Softening the springs to the point your truck is sitting lower (sagging) is probably not the best idea. Your front suspension is the same as F-1 with different backing plates, hubs, and drums. Any of the lowering options for an F-1 will work with your F-3. I don't have any experience with with these since I like my truck to sit like a truck, but others on here should be able to advise you. Maybe dropped spindles? I think other modifications are needed when lowering the front end, like adding caster correction wedges...
VCF3's Avatar
VCF3
Another dumb question: I going to run a pre '72 9". I should make modifications to put shocks on that right? The current Timken rear doesn't seem to have any place for shocks.
Old May 27, 2014 | 08:47 AM
38 coupe's Avatar
38 coupe
The best way to add shocks with a 9 inch conversion is to get a pair of the bottom plates from an F-2. The diameter is correct for a 9 inch and there are shock mounts built in. here is the stock setup on my F-2:
Old May 27, 2014 | 09:02 AM
obscurity's Avatar
obscurity
Just curious, where are you located?
Old May 27, 2014 | 09:11 AM
aussiecowboy
I bought a set of F2 shock mounts for mine, they bolted straight on. The other option for wheels and axle is a dana 60 conversion and F2 wheels which are 16" single piece. Cheap and fairly easy to find, I have 7.50 x16 tyres on mine and they fill the arches nicely.
Old May 27, 2014 | 10:06 AM
VCF3's Avatar
VCF3
I'm in Medina Ohio. Yes dana 60 has crossed my mind, might be a good option. Thanks
Old May 27, 2014 | 10:48 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Do F-3's already have the upper shock mounts?
Old May 27, 2014 | 10:56 AM
aussiecowboy
No, they don't.
Old May 27, 2014 | 05:52 PM
38 coupe's Avatar
38 coupe
aussiecowboy brings up a good point about the tires filling up the fender openings. In my opinion the 3/4 ton trucks look good as trucks with 8 lug wheels, 7.50-16 or 235/85R16 tires, and not too low. The larger look of the 3/4 ton doesn't go well with 5 lug wheels, smaller tires, and a lowered truck.
There were a couple threads recently about 8 lug disk conversions for the 3/4 ton trucks.
Threads here:
https://www.ford-trucks.com/forums/1...-pictures.html
https://www.ford-trucks.com/forums/1...rsion-kit.html
and internet article here:
http://www.fatfenderedtrucks.com/f2_f3_discbrakes.html
Also, it is also hard to argue with the strength of a full floating Dana 60 rear axle from a 1972 or earlier F-250 (back through the 60s, not sure the earliest that had the Dana 60). Use a 4.10, 3.73, or 3.54 ratio depending on where you want pulling power vs higher speed capability.
Old May 28, 2014 | 12:14 PM
VCF3's Avatar
VCF3
Great info 38coupe, that first post by briznasty is really good thanks.
LEADSLED52
30
Jun 21, 2010 03:01 AM
Pa&Nic51
Mar 27, 2009 09:29 PM
elliot
Oct 27, 2008 07:01 AM
Christopher2
Aug 16, 2004 09:45 AM
51dueller
13
Apr 8, 2003 01:18 PM
