cab swap 76 std to 78 super
Old Jul 6, 2003 | 12:43 AM
nosjocky's Avatar
nosjocky
I have a 76 f-150 4x4 longbed. how hard do you think it would be to swap on a supercab from a 78 f-350 2wd? are the front mounts the same with? i was thinking to cut the bed. has anybody done this? and i would half to finish by september
Old Jul 6, 2003 | 02:49 AM
baileybilt's Avatar
baileybilt
i've never done it but a friend of mine is a big supercab fan who has set cabs on different frames and he says it takes quiet a bit of fabricating because the frames are different. but the front should be the same
Old Jul 6, 2003 | 03:48 PM
Txquadhunter24's Avatar
Txquadhunter24
The Rear Cab Mounts for the Super Cab are Farther back on the Frame then a Reg. cab. Most have a hard time trying to under stand this, The easiest way to see it is by placing a reg. and a super cab side-by-side and look where the rear cab bolts are.
naylor2009
Dec 27, 2013 11:02 AM
balingwire
Sep 19, 2013 10:46 AM
supercabfreak
Dec 5, 2010 10:39 PM
cjben
Jan 29, 2006 01:45 PM
78ford514
Dec 13, 2005 10:09 PM
