OK, so this has been one of those minor "what the hell?" things I noticed on my rig and I'm wondering if it's something weird on mine or if this is factory designed.
The wiper stalk - for front wipers, the first detent is the slowest setting...the further you turn it the shorter the interval between sweeps, with the last detent before steady on having a very short interval between sweeps...the firs detent after that is the 'slow' steady on, the next setting is the 'fast' steady on.
The rear wipers are reversed...the first detent has the shorter delay between sweeps...the second detent has the longer delay between sweeps.
Is this something on all rigs, or did maybe the prior owner replace something on mine that has reversed my settings?
With my 03, the first dent up on the rear wiper is the longest delay between wipes, with the next one up being the quickest setting. There are only two settings, besides the spray and clean setting...
...and that would make sense since it matches the front wipers...but...
Originally Posted by jspence105
Mine is the same the first setting is a 2-3 second delay the second is around 10 seconds.
...this one is like mine, with the first setting being a 'faster' intermittent and the second setting being a 'slower' intermittent...so maybe they made a change between the 01 and 03 model years?
i thought i was also, since i went front a 2004 to a 2000 i was very confused the first time i used the rear wiper! then going back to a 2002..i suppose i never really thought about it until you noted it.
