Cold start issues... I need help
Old Mar 16, 2014 | 06:56 PM
1brenth's Avatar
1brenth
I am having cold start problems that I cant get figured out. Can you guys help please. It all started when we had below zero weather and I couldn't get started. If I keep plugged in, it will start, but if not what happens is when it is around 30 degrees and I try to start it is like I loose connection to the batteries and it don't even turn over then its like you hear the starter disengage and sometimes when you try it again it will then turn over and start fine. I have replaced the Starter, glow plugs and harness gaskets, both batteries and the alternator. I am well over $1000 into this and cant afford much more. Can anyone help here? 2002 7.3 Super Duty
Old Mar 16, 2014 | 07:31 PM
F350-6's Avatar
F350-6
Welcome to FTE. What kind of shape are your battery cables in? Next time you have issues, turn the key to start and hold it there for 10 or 15 seconds if nothing is happening. Then quickly jump out and feel the battery cables to see if anything is hot to the touch. A hot cable means you've got an issue there. Either corrosion or a loose connection.
It would also be a good idea to check and clean all your ground connections since those can corrode or become loose and cause a no start.
Old Mar 16, 2014 | 07:33 PM
timmyboy76's Avatar
timmyboy76
switch to syn 5/40
Old Mar 16, 2014 | 07:57 PM
1brenth's Avatar
1brenth
Cables seem to be in good shape, nothing is getting hot and I have also checked for cracks or hard spots in them for any wear. I also have used Rotella t 15/40 for years, should I change now?
Old Mar 17, 2014 | 03:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
oil has nothing to do with it.
it is electrical.
jprankin
22
Nov 18, 2014 06:53 AM
Yukon
May 7, 2014 10:51 AM
Quick444
28
Dec 12, 2009 01:47 PM
jopiel
Jan 21, 2008 02:04 PM
lexasgs400
Sep 10, 2007 11:39 AM
