Anybody swap the 2014 rotors onto their trucks?
Old Feb 25, 2014 | 05:53 PM
ngng's Avatar
ngng
Curious how it went and what additional hardware was needed.
Old Feb 25, 2014 | 07:41 PM
senix's Avatar
senix
I thought 2013 was the change to the bigger size..?
Old Feb 26, 2014 | 12:27 AM
Pacman51's Avatar
Pacman51
You're going to need more then just rotors......new calipers and caliper mounts.......not sure if the mounts are bolted to the uprights or are part of them....if bolted then fine....if not then new uprights to make way for the larger diameter rotor.......could add up to lots of money!
Old Feb 26, 2014 | 12:57 AM
ngng's Avatar
ngng
Is this from experience, or just speculation? Often you can run larger rotors without changing calipers. If the caliper mounting brackets are part of the uprights, they should be easy to machine.
Old Feb 26, 2014 | 11:51 AM
PlayersZ28's Avatar
PlayersZ28
What's the difference in rotor size for the fronts? Are the pad surface areas larger as well?
Old Feb 26, 2014 | 01:53 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Both Front and rear rotors are larger on 13+ models. They also have the same size rotors fitted front and rear ('12s and earlier have smaller rotors on the rear than the fronts)
Calipers/pads also changed to increase pad surface area by around 30% or so too
Master cylinders also changed, IIRC
Old Feb 26, 2014 | 02:45 PM
PlayersZ28's Avatar
PlayersZ28
So at a minimum it would be master, calipers, rotors and pads. That's if they handled the larger rotor with long mount legs on the caliper and left the spindle the same.
Old Feb 26, 2014 | 04:25 PM
Davgt500's Avatar
Davgt500
I would definitely be interested in swapping out for larger rotors & calipers. Interested in seeing if it can be done reasonably.
Old Feb 27, 2014 | 12:33 PM
PlayersZ28's Avatar
PlayersZ28
I suppose the first thing to know is if the spindles are the same part number for the different years with brake size differences.
bignast1
Nov 16, 2018 07:11 AM
BigBlkEX
Jul 24, 2014 12:04 AM
Sixoh
1983 - 2012 Ranger & B-Series
Mar 8, 2011 05:24 PM
wgotthardt
1997 - 2003 F150
Jul 25, 2009 11:39 PM
carbonmetallic
Apr 9, 2009 11:04 PM
