Typewriter is in my engine bay!
Well 3200 miles total on new truck. first oil change done at the dealer was done at 2500 miles. Had them put in 5-40 full motorcraft synthetic .
Low and behold my $66,000 truck sounds like it has a bad lifter. Erratic and random LOUD typewriter noise from under the hood.
Great, now what? For the dreaded typwriter issue, has there been any relief? I'm thinking of going and getting tha oil modifier from a stealer ship and dumping it in to see if that fixes it. But really, WHAT THE HECK IS MAKING THAT NOISE?
Mine started after the second oil change. After 500 or so miles into the oil change with the 10/30 Motorcraft it would stop ticking. Next oil change, I switched to 5/40 Valvoline. Ticked for the entire 5k mile oil change interval. Just got done changing it today. Went back with the 10/30 Motorcraft. It is very annoying.
Ok, can someone get technical and tell us what is causing the ticking? I have not experienced it, but I'm also using T6.
It was 10/12 maybe? My chassis has 202,000 on it. I've been busy, I haven't been all that active on here in a while. So far this month I've driven 4400 miles and have to run another 1600 next week. Needless to say I change my oil every 4-6 weeks. I have 2 cases of oil, 2 fuel filter kits, and a case of Motorcraft oil filters in my garage at all times.
Don't wanna derail the thread but yes, I think the motor smooths out after a while.
TSB 10-19-2
Mine does this all the time, very annoying.
6.7L DIESEL—TICK/TAP NOISE AT IDLE TSB 10-19-2
FORD:
2011 F-250, F-350, F-450, F-550
ISSUE Dealers should not attempt to compare any
Some 6.7L diesel equipped vehicles
may exhibit a customer vehicles exhibiting this noise with other
ticking noise at idle after an engine oil change. It is similar vehicles as the noise is different from vehicle
often referred to as Typewriter Noise because of its to vehicle and this may lead to the incorrect
similarity to the sound of random typing on a conclusion that the vehicle has a condition.
mechanical
typewriter. Customers may report that Typewriter Noise is a normal operating
when near a building, wall or drive
through window, characteristic of this diesel engine. This noise has
that this noise can be heard from inside the cab. no short or long term effects on the engine. Do not
attempt repairs to eliminate this noise. This noise is
ACTION characteristic of the 6.7L diesel engine and will
Follow the Service Information to inform the typically cease or diminish significantly within the oil
customer of the characteristic. change maintenance interval.
SERVICE INFORMATION Refer to vehicle Owner Guides and Maintenance
Guides for approved engine oil viscosities and
The relationship between the oil film
, crankshaft usage information. Use of different oil viscosities will
journals, bearing inserts and engine cylinder
block not eliminate this noise and is not recommended.
produces a sound that is heard as a ticking noise. Customers should be informed that these conditions
The overall noise reduction in engines
produced do not affect engine durability and no repairs are
today makes this noise seem new when, in fact, it necessary.
was present in prior model year vehicles, but
masked by other noises in the past. Because the WARRANTY STATUS: Information Only - Not
6.7L diesel engine includes a number of design Warrantable
improvements to reduce diesel engine noise,
Typewriter Noise can be more noticeable than on
previous products. Typewriter Noise is not
detrimental to engine function or durability. Other
manufacturers of diesel engines have reported the
presence of this condition for a number of years.
Build tolerance stack-up from engine to engine
contributes to perceived differences in noise
intensity. When engine temperatures reach 150 °F
(65 °C) or higher, (from engine idle up to
approximately 1700 RPM’s), this noise can typically
be heard at the front wheel
well and is often
isolated to the transmission bell housing or oil pan
area.
FORD:
mechanical
area.
In other words, they really don't know. But sticking with the recommended weight and not topping off seems to reduce eliminate the typewriter, at least it did in my truck. Just to make sure I, I made the noise come back by filling the crankcase up during the last oil change couple days ago. Drain some out, noise disappeared. Why is a mystery. Seems us daily drivers hear this more than the folks using the trucks to work hard daily.
I've read elsewhere that the factory puts in a dose of Motorcraft XL-17 to prevent this on the new engines, and that adding it with an oil change or as needed helps get rid of the ticking. I haven't tried it yet as I have not gotten my first oil change, but I'm wondering if anyone else on the forum may have tried it and what were the results.
What is the ingredients of this xl17 ? Ive found some info that says its hydraulic fluid?But no clear cut info on what it is.Very strange.I didnt get any increased clatter after my oil change.Atleast not noticable,but I know Ive read that a lot of people have.
