Holy Spark Plugs
Old Dec 13, 2013 | 08:35 PM
Mikey_23_ny1's Avatar
Mikey_23_ny1
Holy Spark Plugs
2005 Expedition Eddie Bauer 140,000 miles
The truck is still new to me so i wasn't sure of the service history at all. It has been sputtering and choking out lightly while highway driving only and MPG's has been horrible (9.6 - 10.8). The symptoms were pointing towards the plugs from what i can tell so i figured its best to change out the coil on plugs and spark plugs (especially since i wasnt sure if they were done). Im guessing from the looks of the plugs, they were never done but some may feel differently. I did massive amounts of research on this before tackling the job and followed fords instructions accurately. I still wound up breaking 5 out of 8 plugs (i even cracked them a touch, sprayed and let them soak over night). These plugs were in such bad shape, im surprised the truck even started let alone run.
After the replacement i drove it 75 miles in total. MPG's went from 9.8 to 13.5 city and highway it went from 10.8 to 15.5. The truck now purrs and doesn't skip a beat. Major difference and runs like new.
These are what our plugs look like with 140,000 miles on them (or at least mine did).
Update: i just realized from looking at the pics, one of the plugs on the passenger side is 'autolite'. So apparently someone has messed with it at one time or another. Strange on how just one was changed. Might that have been from the original batch (mixed in with the motorcrafts)?
DRIVER SIDE
PASSENGER SIDE
Old Dec 13, 2013 | 08:39 PM
cb_13's Avatar
cb_13
Looks like one has been replaced before. You have an autolite in with all those motorcrafts.
Old Dec 13, 2013 | 08:53 PM
Mikey_23_ny1
funny because i didn't notice it until i looked at the pics.. I was probably too busy cussing...
Old Dec 13, 2013 | 09:04 PM
JWC 3's Avatar
JWC 3
Where I work it is common procedure to replace a plug if the coil is bad . So a coil may have gone and been replaced , with a new plug also . That may explain the one odd plug .
Old Dec 13, 2013 | 09:09 PM
Mikey_23_ny1
good point!
Old Dec 13, 2013 | 09:11 PM
cb_13's Avatar
cb_13
The factory plugs should have a dot of white or green paint on the end. I use a 3/8 impact to remove those plugs with the engine warm. Some just break no matter what though.
Old Dec 13, 2013 | 09:13 PM
cb_13's Avatar
cb_13
I'm sure you're right on that. I used to do the same until this plug design came along. Didn't want to risk breaking the plug and spending an hour removing it for free.
Old Dec 13, 2013 | 09:24 PM
JWC 3's Avatar
JWC 3
Ah... But if it breaks , we charge. Sorry , poor design . Ain't my fault if I follow all the steps and a plug breaks . I do not work for free .
Old Dec 13, 2013 | 10:57 PM
cb_13's Avatar
cb_13
You mean to tell me you charge people for work and the technician gets paid? Is there any way you could explain this concept to the jack root service advisors I work with?
Old Dec 14, 2013 | 10:55 AM
r2millers's Avatar
r2millers
Mickey doesn't indicate if the plugs came out in the order that they lie. If so, then #3, but if the #4 plug, I could see the original owner just giving up on that cylinder and changing only 7.
Something I'd never do myself, however, it's not to say it didn't cross my mind!
Old Dec 14, 2013 | 11:12 AM
Mikey_23_ny1
They are grouped by driver and pass sides but not sorted in order of removal. Cylinders, 1,2 and 7 came out intact. All in all, I don't think the replacement was that difficult (provided you have the right tools). I'm a general contractor (shade tree mechanic) so my mechanic tools only consist of craftsman. I managed just fine. It's more time consuming than anything.. Took me 5 hours...
Firewall
4 8
3 7
2 6
1 5
Radiator
Bertha1
43
Sep 2, 2019 03:26 PM
Fedele33
May 25, 2019 11:17 AM
CDP2011
Mar 27, 2018 06:30 PM
Trailblazen
2009 - 2014 F150
17
Jan 25, 2016 07:29 PM
Grubbworm
General Automotive Discussion
Nov 16, 2011 12:03 PM
