If you got a buddy knows a fair bit bout mechanics doesn't take long but for us amateurs. Worst part is draining coolant removing intake.
Draining coolant is like a 30 sec job run it to a operating temp and then pull the bottom 3 " hose and its comes out like a fire hose. then flush with hot water with the 3: hose put back on ...
If that does not scare you then go for doing yourself the rest is kit bolt on that youtube/google can help ya with.
No EGR delete is a 6.0 diesel recommendation nothing to worry about on a gas powered truck. 6.4 diesel has a similar delete
