EGR replace vs. EGR delete?
Old Sep 19, 2015 | 02:05 AM
kyleec69's Avatar
kyleec69
I have a 2004 6.0 power stroke v8 turbo diesel that, at least from what I'm being told, needs to have the EGR cooler and the oil cooler replaced. The best price I've been quoted is $3,500.00! Does this seem reasonable? And, would an EGR delete be the better way to go?
Old Sep 19, 2015 | 02:17 AM
jswartz84's Avatar
jswartz84
That sounds exactly like the quote I got for the same job. Parts were $400 with the EGR delete so I did the work myself and saved $3k.
I'm a fan of the EGR delete.
Old Sep 19, 2015 | 02:22 AM
kyleec69's Avatar
kyleec69
Really! I was told $350.00 for EGR cooler and $900.00 for oil cooler!
Old Sep 19, 2015 | 02:43 AM
jswartz84's Avatar
jswartz84
An OEM oil cooler is $300.
EGR deletes are anywhere from $50-$300. I'm not sure what an EGR cooler costs.
Old Sep 19, 2015 | 02:45 AM
kyleec69's Avatar
kyleec69
Right on! I sure appreciate your input!!!
Old Sep 19, 2015 | 02:49 AM
jswartz84's Avatar
jswartz84
Oil Cooler Kit - Riffraff Diesel Performance
Her is an OEM oil cooler from Riffraff.
ADT_60_CHK
This is the EGR delete I went with.
Old Sep 19, 2015 | 03:02 AM
kyleec69's Avatar
kyleec69
ADT_60_CHK
Thanks!!
Old Sep 19, 2015 | 06:38 AM
npccpartsman's Avatar
npccpartsman
I see that you're in Oklahoma. What part? I'm in the Fort Smith area.
Old Sep 19, 2015 | 06:44 AM
kyleec69's Avatar
kyleec69
Born and breed in Lawton!
Old Sep 19, 2015 | 12:03 PM
Kemicalburns's Avatar
Kemicalburns
Check into the IPR Gen II egr delete. its a bit more than whats already been posted here although you will see why it costs a bit more. I will be going with this unit when the time comes.
Old Sep 19, 2015 | 01:11 PM
jswartz84's Avatar
jswartz84
The IPR Gen 2 is pretty nice, if I had looked around more, I would have bought it.
The ADT kit has never given me any problems in the 4 years it's been installed but I didnt use the supplied hose clamps with it either, they slipped before getting as tight as I wanted them.
Old Sep 19, 2015 | 01:27 PM
kyleec69's Avatar
kyleec69
One more thing fell'as! Diggin' around on YouTube, and whatnot, I've been hearing alot of seemingly knowledgeable mechanics recommend just welding the ends shut on both ends of the existing EGR cooler. What do y'all think about that procedure?
Old Sep 19, 2015 | 03:41 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I think it's a good option if it's done right. Don't use freeze plugs, cut some nice thick steel plugs and the welding has to be good. You do keep the little blue hose that leaks often but the up pipe is still supported where it bolts to the egr cooler. Its very possible to pass a visual smog check with this mod, it looks factory and several have posted their trucks have passed an exhaust sniffer test also.
Old Sep 19, 2015 | 04:00 PM
HT32BSX115's Avatar
HT32BSX115
ADT_60_CHK
Are they sort of making a false claim with the above kit though?
*No tuner required! Kit does not require removal of the EGR solenoid
and will NOT trigger any check engine lights! If disconnecting the EGR
solenoid triggers a check engine light, you can leave the solenoid in place
and connected after completing the rest of the delete kit installation.
They make the kit for 2003-2007 models. Don't 2005 and up require a tuner to prevent the Check engine Light?
Old Sep 19, 2015 | 04:57 PM
evan1242's Avatar
evan1242
Some years will throw a CEL for EGR low flow.
So yes, that is a false claim for some trucks.
