Sponsored by: Auxito
98 Ford F150 Problem.Maybe Coil packs??
Old Nov 6, 2013 | 12:35 PM
James William Combs's Avatar
James William Combs
Question 98 Ford F150 Problem.Maybe Coil packs??
So this is my first post I have a ford f150 supercab XLT with the 4.6L triton.
It starts and idles absolutely fine but when i push the gas to fast(when in park) it bogs down. I just changed the fuel filter aslo...No change.
(2) If I floor it it Bogs then goes up to about 3000rpm (about halfway) and has trouble moving over that RPM or halfway. like theres a restriction of some sort.
(3) If I gradually push the gas, it will go up in rpms and i can get it to about 2000 rpms then I can tack the rpm gauge out if I wanted. but never do.
(4) Also when driving, it seems as if its lacking power..and just to add it does all this stuff while in gear also..
(5) When running It smells of an exhaust leak. but I cant find one. And I cant smell it in the cab.
So there it is. If I think of anything else, or do anything. I will keep posting. Thanks so much.
Old Nov 6, 2013 | 12:48 PM
projectSHO89's Avatar
projectSHO89
There's a rev limiter in the PCM's programming to keep you from blowing up the torque converter when in Park. You might be hitting that.
Old Nov 6, 2013 | 12:59 PM
James William Combs
Thanks for the info...but this is definitely something not right...not u..the truck
Old Nov 16, 2013 | 09:44 PM
sKuLz88's Avatar
sKuLz88
Could be a cat trying to stop up. Are you having any cooling issues, or do you hear a rattling in your exhaust?
Old Nov 17, 2013 | 05:56 AM
Bluegrass 7's Avatar
Bluegrass 7
Here is a run down as I see it, from your post.
Is there any codes set?
A. When the throttle is operated the throttle position sensor has to tell the computer to do a number of things one of which is to add fuel depending on how fast the throttle position changes.
B. If the fuel pressure is getting very low there is not enough fuel to make power on. Check the pressure with a gauge. Could be the regulator or the fuel pump.
C. The Mass Air Meter also has input to the computer for fuel addition vs air flow.
D. The exhaust system blocked, strangles the motor from passing exhaust out. May be the smell. A back pressure check could be made but seems both sides would have to be blocked for your level of power loss unless it is from the muffler back where the two banks come together. Tail pipe bent shut etc.
Most of these should cause code to set so must be checked out until you find the issue.
Use of a scanner to look at live data should show the effects of and possibly the cause of the issue.
Live data for the TPS signal, the mass air output signal, the fuel trims tables for both short and long term, oxygen sensor activity etc.
This may be more than your prepared to do but sometimes it's why you need to go to the doctor for help.
Good luck.
Old Nov 17, 2013 | 11:14 AM
projectSHO89
The OP last visited the site on the day of his initial posts. You're likely chatting to yourselves.
Old Nov 18, 2013 | 08:17 AM
James William Combs
Thanks a lot for all the input...most of the problem is fixed I had unhooked the battery before all this to put a new fuelfilter on and it was off for a couple days ...it cleared the computer I drove it for about 5 hours and its running awesome!!!! Still some issues with the smell and breaks ...I'll post back later as I'm at work...thanks so much!
Old Nov 18, 2013 | 09:19 AM
James William Combs
Exhaust-&-Breaks
So here's an update on the situation..
The computer Just had to run a full cycle after I had the battery disconnected for a couple days. and the truck is running much better...
(I forgot that I had done that to change the fuel filter and didn't mention it in the original post..(SORRY)....I also done a complete SEAFOAM. Throttle body, Vac lines, and gas..
1) So now on to the problems...So the exhaust smell is still there, and the power issue is...(read below)
when I give it gas it still feels a little sluggish but I can still feel that is has power, just something seems to be restricting it..(If that makes since)
2)BREAKS- When I am driving and coming to a stop there is a (thump) feels like from the front.... And the break kind of comes up a little...
(So you can feel the thump in the break also).. and not just only hear it...
Im thinking maybe air in the break lines?? (also this don't happen at every stop....
when I push the breaks the first time without pumping them the break peddle goes all the way to the floor... is this because its not ABS??..
So there it is!!... if someone can help its very appreciated (and this is ALL very helpful by the way)
And I get these in my e-mail.. so I know when someone posts a reply so (YOUR NOT REPLYING TO NOTHING)
Jarhead316
Apr 3, 2016 09:25 AM
BuiltFordTough100
1997 - 2003 F150
Nov 29, 2012 10:22 PM
adraoport
1997 - 2003 F150
Apr 24, 2011 04:00 PM
Catdave
2004 - 2008 F150
Sep 30, 2006 08:33 PM
Brother65
3.0L V6
Jun 7, 2004 05:12 PM
