Sponsored by: Auxito
98 f150 no 4wd
Old Nov 3, 2013 | 01:21 AM
jayron's Avatar
jayron
98 f150 no 4wd
Hello my 98 f150 a problem it won't shift into 4wd the lights glow and i can hear it click but nothing. When in 4L the engine gears down but nothing. I took the shift motor down and turned the **** the motor turns but nothing i took pliers and manuly turned the shaft the front wheels still don't turn. Any thoughts thanks a million Jayron
Old Nov 3, 2013 | 07:03 AM
Bluegrass 7's Avatar
Bluegrass 7
That point is not the end of the operation.
If the 4L dash light comes on but no front lockup, check the 'actuator' on the front axle for pulling the axle lock in.
If this is not happening you should not have 4H either because both need the same action at the same place.
The actuator is vacuum operated by solenoids on the firewall.
If it is locking up but no drive in only 4 L then the trans is in trouble because the drive path through the trans changes for 4L to get the low gearing..
If the shift points change for upshifting it tells you the transfer case motor has run to the 4L position ok but no guarantee the internal change took place properly.
After checking this operation out you should be able to see the trouble area.
Good luck.
Old Nov 3, 2013 | 08:20 AM
steve(ill)'s Avatar
steve(ill)
there are two vacuum hoses to the front axle. one has vacuum when in 2 x 4, the other has vacuum when 4 x 4.. Pull the hoses off, turn the switch and feel for the vacuum.. IF vacuum is o.k., spray the vacuum cylinder with penetrant and tap or pry on the end to get it to move in and out. That is the front end engagement.
Old Nov 4, 2013 | 06:13 PM
Dutter 2's Avatar
Dutter 2
I just got done messing with my truck with it same problem and it sounds like internally the t case isn't engaging or it front drive shaft is broken like what I had. But tilling out the t case is easy jus listen for it engaging or put it in low range and drive it and feel the lower gears. Or just see if u can turn the front drive shaft by hand once u put in 4
Old Nov 5, 2013 | 07:13 PM
jayron's Avatar
jayron
Hi Bluegrass thanks for the info i checked the vacuum lines one was broke. I tried the local parts places they don't have that size of plastic line is it special
order?
Old Nov 5, 2013 | 08:08 PM
Bluegrass 7
Good to hear you located the issue.
Good luck.
Old Nov 9, 2013 | 10:04 AM
jayron's Avatar
jayron
Hey thanks to all that responded to my problem' I found 1/8" plastic line at a napa parts store worked great you guys saved me a ton of money with tax it came to $5.30 so thanks again.
Capt No Slack
2004 - 2008 F150
Jan 6, 2017 07:58 PM
cemcjoe
1997 - 2003 F150
Jan 28, 2014 10:40 PM
93 mix 'n match
1997 - 2003 F150
Jul 26, 2010 01:07 AM
Czacha
1997 - 2003 F150
Dec 27, 2009 03:19 PM
Gregxlt
1997 - 2003 F150
Feb 3, 2004 02:05 PM
