Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1964 f600
Old Nov 2, 2013 | 08:13 PM
Dragontvb's Avatar
Dragontvb
1964 f600
I recently got a 1964 f600 that had sat for 16 year's. Took 2 days but got it running and wow it runs pretty nice for being 50 years old and sitting for the last 16 year's. So i am tring to find out what engine it has the engine code is A and i cant not find anything that says what A is.
Also i was wondering if anyone knows if i can convert it from power brakes it has now to manual brakes? I would think the only difference is the master cylinder but the mount holes are different so i was not sure if it was doable or if anyone else has done it.
Old Nov 2, 2013 | 10:18 PM
jmtbiggin's Avatar
jmtbiggin
Congrats on the project. I am no help on the questions. You ain't alone out there. I am knee deep in my 61 f500. Good Luck
Old Nov 3, 2013 | 12:05 PM
Truck Guy99's Avatar
Truck Guy99
Pictures of the engine would be helpful. Pics of the whole truck are appreciated. As you can see, I used to have a half ton version of your truck so I'm partial to them.
For the codes and brake questions, PM NumberDummy. He can tell you all you need to know and then some.
Old Nov 3, 2013 | 11:18 PM
85e150's Avatar
85e150
A '64 is probably a 292. Does it have a backwards exhaust manifold with a crossover pipe from the driver side to the passenger side manifold?
Brakes. Do you want to be able to stop the truck? You need to fix the hydrovac system if it is not working.
You will not be able to stop the truck even empty if all you have is a single pot master cylinder without power assist.
Rebuilt hydrovacs are available. Once you determine the model number etc, they are easy to find.
Wheel cylinders & linings are easy to find, drums a bit tougher.
If you post the VIN and the info from the warranty plate on the door, more can be determined via decoding. There might be a couple different sized brakes for example, not sure the decode can tell you that but will help steer you in the right direction.
Old Nov 15, 2013 | 06:23 AM
big job's Avatar
big job
Napa for the vac booter about $180
Old Dec 22, 2013 | 03:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I recently got a 1964 F600 that had sat for 16 year's. Took 2 days but got it running and wow it runs pretty nice for being 50 years old and sitting for the last 16 year's.
I'm trying to find out what engine it has. The VIN engine code is A and i can't find anything that says what A is.
Ask and ye shall receive...
A VIN engine code (4th digit): 330 2V Medium Duty FT engine / A only used 1964/65.
C VIN engine code (4th digit): 330 2V Medium Duty FT engine / C used 1966/78.
FT: Distributor located in front of carburetor, valve covers have 5 bolt holes per side.
292 Y block distributor located behind the carburetor.
biggut
Aug 29, 2013 09:57 PM
cypslady
13
Mar 2, 2013 09:29 PM
mdkallas
Dec 24, 2007 11:37 PM
psonnier
Sep 26, 2004 09:03 PM
svtlight
1947 and Older Ford Trucks
Sep 23, 2003 05:20 PM
