Rear Audio Control Cover Removal
Old Jun 20, 2003 | 01:04 PM
ineedashot's Avatar
ineedashot
Hello to All!
I need to remove the cover were the rear audio controls in the center console are. I will be installing a harness (to add an aux. to the stock audio) and also install a bracket for a monitor.
So I need to remove the cover to access the harness and locate an area to affix the bracket. I don't want to break anything...
I have an 02', so has anybody done this before???
I have the Truck CD, but I can't find instructions anywhere for this.
Will appreciate any input.
Thanks!
H
Old Jun 20, 2003 | 06:09 PM
Dalavar's Avatar
Dalavar
Does your rear console have the flip out cup holders?
If so when it is open there are 4 screws that are accessible. Take these 4 out and then lift up from the bottom slightly, be careful of the wiring harnesses they are kinda tight and on mine were wrapped around this metal hook to keep em tight and from wiggling around.
Old Jun 21, 2003 | 08:17 AM
1999XLT's Avatar
1999XLT
If you mean the rear of the center console, on mine you just pull it ond it comes off. But then again mine is a 99.
Old Jun 23, 2003 | 07:55 AM
ineedashot's Avatar
ineedashot
Dalavar,
Thanks for the instructions, mine have the cup holders. SO, I will follow your directions.
Thaks to you too "1999"!
H
Old Jun 23, 2003 | 09:49 AM
Dalavar's Avatar
Dalavar
I tore mine apart trying to find a way to upgrade my VCP to a DVD player =) Ford and their silly proprietary plugs.
Old Jun 23, 2003 | 10:52 AM
ineedashot's Avatar
ineedashot
Dude, it's easy!
I found this connector, the brand is Peripheral. Is a jumper that connects to the OEM rear audio control harness (like a bridge, in between the harness plug and the audio control terminal) and the other end of this jumper has 3 audio inputs (RCA plugs). This generates 3 individual auxiliary channels right into the OEM head unit.
I don't have the link to the site with me (I'm at work) but have the info at home and the model and picture of this unit, the cost is like $90.00.
This is what I will buy to hook up my X-Box to the truck ( for DVD source and games).
My setup will be:
300W Power Inverter (Power for X-Box, TV Tuner and 12" Flat Screen)
View Sonic TV Tuner (Plug Flat Screen to it)
12" View Sonic Flat Screen (video source)
Peripheral Connector (To add audio to system)
And everything will be portable, sweet!
I may need another power inverter since the power point in the truck only generates half the capacity of the Amperage times 10, in this case like 10Amp (time 10 = 100W), fuse is rated at 20Amps (half of that is 10 Amps). This info is in your owner manual.
Screen pulls like 60W
X-Box pulls like 100W
TV Tuner like 30W
I'm looking forward to completing this project!
H
Old Jun 23, 2003 | 01:06 PM
ineedashot's Avatar
ineedashot
Here's the link...
http://www.installer.com/aux/index.html
Old Jun 24, 2003 | 09:22 AM
2000Expy's Avatar
2000Expy
Dang!! And I paid $99 for that stupid CD Changer harness. I coulda saved $30. I wished I'd known about this site before. Thanks though. So I can put RCA jacks in with the rear controller harness? That's cool. So you can run sound through the stereo, right?
Old Jun 24, 2003 | 09:32 AM
ineedashot's Avatar
ineedashot
You got it!
This harness adds three separate auxiliary sources. Well, I guess you can only play on at a time, but remember with the rear audio control unit lets say, you can watch a movie and listen to the audio trought the rear speakers while the front can listen to the radio throught the front speakers or just use the headphone jacks for the back...
Old Jun 26, 2003 | 09:24 AM
Dalavar's Avatar
Dalavar
sweet thanks for the info, but isn't that just for injecting an audio steam into the factory head unit? I need something that will let me add a video signal to the factory Rear Entertainment System, it has a second set of RCA plugs on it but once you remove the little cover to plug them in you can't put it back on and the wires would be exposed (yuck).
Ideally I would like to yank the VCR and just swap it with a DVD player but all power and video signals to the LCD are on a square ford plug.
Old Jun 26, 2003 | 10:57 AM
ineedashot's Avatar
ineedashot
These Guys @ installer.com MUST have the right connectors to convert the Ford plugs. Check their site, browse around. I'm sure it will pay off...
H
BIGDZL
6.7L Power Stroke Diesel
17
Apr 11, 2018 11:29 AM
RailDawg
May 3, 2017 04:14 PM
Casper99
Dec 27, 2016 06:56 PM
BigBlueX
Apr 27, 2016 12:05 AM
powerkmac
Apr 25, 2014 07:48 PM
