Garage door clearance issues. Found out about high lift.
Old Sep 13, 2013 | 04:42 PM
housedad's Avatar
housedad
Even though it sounds like it, this is not about clearing the roof of my Ex through the opening. With the Ex in current configuration at 82 inches tall and the door opening at 83 1/2 inches tall, it just scrapes by.
The real issue is that I'm going to put in a 2 post lift in the garage. The ceiling is 11' 3" to the trusses, but the door opening is only 7 ft tall with the rails suspended from the trusses near that height. This means that the door MUST be closed to raise the ex at all.
So I did some searching around and found there is a solution.
I'm sure a lot of you know about this, but for those like me that don't, this is the info you need.
You can put together a high lift conversion for your sectional garage door.
The information and parts can be gotten from these people: (I'm sure a lot of vendors can do it) You need to change your tracks, springs, and cables.
High Lift Garage Door Conversion
To be able to raise the door, you have to get rid of your old chain or screw drive garage door opener and get a Jackshaft opener like the one below.
<iframe width="560" height="315" src="//www.youtube.com/embed/FhursGCxrso" frameborder="0" allowfullscreen=""></iframe>
So, I just put everything on order. Unfortunately I won't be able to get around to installing it until the middle of October.(I hope)
Old Sep 13, 2013 | 06:33 PM
mtnsammy's Avatar
mtnsammy
Nice thought. I do not have my lift yet but you idea has merit. I have a 9 foot door with 11 foot ceilings. I am thinking of adding the extensions and one more door panel. This way it will lift with my Martin opener still and I will have the full opening but it will be 18" higher up. My cost should only be the 1 panel and the 2 extensions to the tracks.
Old Sep 13, 2013 | 07:41 PM
LivingLarge's Avatar
LivingLarge
Looks like a nice set up Bion, good luck with it!
Old Sep 13, 2013 | 08:27 PM
ufvj217's Avatar
ufvj217
[QUOTE=mtnsammy;13530955]Nice thought. I do not have my lift yet but you idea has merit. I have a 9 foot door with 11 foot ceilings. I am thinking of adding the extensions and one more door panel. This way it will lift with my Martin opener still and I will have the full opening but it will be 18" higher up. My cost should only be the 1 panel and the 2 extensions to the tracks.[/QUOTE
Shouldn't have to add another garage panel
Old Sep 13, 2013 | 08:56 PM
sammie0126's Avatar
sammie0126
Ok but isn't the issue for most people the size of the garage door opening which is based on the trusses in your garage? I know my issue is the clearance at the very edge of my door opening, I could move the door up 4" feet I have the clearance in the ceiling inside the garage but the front of my house would have to be torn out and raised to get it higher. I fit now but barely.
Old Sep 13, 2013 | 09:42 PM
Restlesswildman's Avatar
Restlesswildman
Or you could put low profile tires on the EX.........
So the OP has an interference issue with the garage door opener that runs down the center of the door?
I am one of the ones that has to build a new garage to fit around the Ex....Will have to keep this in mind.
Old Sep 13, 2013 | 10:01 PM
ScaldedDog's Avatar
ScaldedDog
I've had a couple of those 3800s for five years. With an in-ground lift and the opener out of the way, I can lift the Ex way over my head.
Mark
Old Sep 13, 2013 | 10:23 PM
sammie0126's Avatar
sammie0126
Uh no not on my truck!!
Old Sep 13, 2013 | 10:57 PM
wpnaes's Avatar
wpnaes
In my minds eye I see this...
Old Sep 13, 2013 | 11:13 PM
sammie0126's Avatar
sammie0126
OMG that is the image I get as well.....and my brain screams....
NEVER NEVER NEVER!!!! Like the 2 and half men Episode.
Old Sep 13, 2013 | 11:23 PM
housedad's Avatar
housedad
Ouch! I would hate to pay to raise that garage door. All that brick fascia to replace.
Yes, for most people it is the height of their ceiling.
Like you, I have plenty of room to raise my door if needed. I barely fit through my door but that is fine for now. I only have vinyl siding out there now. so the cost would be way less than yours.
The problem for me is that I can't use a 2 post lift and raise the excursion at all with the door opened. The Garage door when opened is just a couple of inches over the Ex as is stands now. Getting the door close to the 11' ceiling would get it out of my way. On hot and cool days I would rather work with the door open. Winter days the door would stay closed of course.
Old Sep 13, 2013 | 11:34 PM
housedad's Avatar
housedad
No, I don't have any real issues with the central door opener I have. I would clear it by 3 to 4 inches even lifting the Ex. My garage is a 2 bay with a single 16 foot door. The lift will be centered in on one of the door bays. (4 foot from edge of door opening) so I just drive it in.
The Jackshaft opener is a requirement of the High Lift door design. Chain or screw type will not work with it. they need to be just above the door opening.
Even though the Ex when on the lift would not be in the way of the opener, getting rid of the monster hanging in space in the garage does have nice appeal!! It is UGLY!
Old Sep 13, 2013 | 11:36 PM
housedad's Avatar
housedad
MY EYES!!! MY EYES!! THEY BURN!!!!
What a nightmare setup that SUV has!
Old Sep 13, 2013 | 11:43 PM
Stewart_H's Avatar
Stewart_H
Very nice heads up, Bion!
Stewart
Old Sep 14, 2013 | 12:45 AM
wallz's Avatar
wallz
Any and all garage door retailers will have the option.
I didnt go into the link, but I'm hoping you went thru someone like that.
I have this info, but I also do sell em, albeit not a lot at this point in time, but in my mind the jack shaft opener is the only way to go, and REALY they are not that more expensive.
