2004 6.0 excursion p0401
Old Aug 29, 2013 | 08:16 PM
Johnnyblaze's Avatar
Johnnyblaze
I had an issue with lots of white smoke. A p0401 code, then the smoke stopped. I removed the egr and cleaned it. All seamed good until two weeks later. Now I have smoke again. Its seems to be only after it is warm. Please help. Do I need a NEW egr valve?
Old Aug 29, 2013 | 09:33 PM
POORBOY1964's Avatar
POORBOY1964
Sounds more like an egr cooler is leaking coolant into your intake the white smoke is steam. park facing down hill over night then pull your EGR valve out and see if it's wet down inside the intake manifold.
Old Aug 29, 2013 | 10:13 PM
Johnnyblaze
I've read a lot of posts on this, and I do think you are right. I have it at the dealer for a diagnosis. I just need to know for sure before I try to take something like this on.
Old Aug 29, 2013 | 11:32 PM
BLADE35's Avatar
BLADE35
Have you had to add coolant
Old Aug 30, 2013 | 08:55 AM
POORBOY1964
Let us know what they say.
Old Aug 30, 2013 | 11:36 AM
daddykitty's Avatar
daddykitty
could be stuck or sticking turbo, restricted up pipe to egr cooler, map sensor tube to intake manifold. ebp sensor tube to exhaust manifold. i have the same damn problem and think it is the restricted up-pipe since i have addressed everything else
Old Aug 31, 2013 | 03:50 PM
Johnnyblaze
Yes, adding coolant.
Old Aug 31, 2013 | 03:51 PM
Johnnyblaze
My dealer has been good to me in the past. I hope they give me a good diagnosis.
ten.mile
Feb 13, 2013 11:58 PM
9228.bobcat
Aug 11, 2012 10:22 AM
pw1926
Oct 12, 2010 12:58 PM
FordSDF250
Jun 30, 2009 10:58 PM
pcarrera
Feb 11, 2008 12:39 AM
