UPDATE: Crank no start, WITH Tousley and Auto-Nation website changes
Old Aug 16, 2013 | 05:38 PM
egregg57's Avatar
egregg57
F350 120k studs etc check signature. Changed oil and fuel filters last night. Ran truck and everything was good. Drove to work 20 miles still running great. On the way home from work, merging on to highway, truck died. Got to side of road safely. Edge insight showed one code V0100. Consult shop manual. Got it towed. Shop pull LPO spring to check for metal ruling out LPO pump. No metal. Motorcraft filters used always.
Oil pressure 13 PSI. Dash oil gauge moves to lowest range mark on indicator, does not move further on crank. Crank is strong. Oil filter removed and valves in housing are free moving.
FICM voltage 47.7v.
Shop ran out of time and is closed for the day. They plan on ruling out ICP / IPR on Monday. Hoping ICP or IPR.
Any helpful hints beyond the Tech Folder from you Master Techs?
Shop said could still be LPO pump failure but is trying to rule all else out.
Eric
Old Aug 16, 2013 | 05:47 PM
99ExpyProblems's Avatar
99ExpyProblems
V0100? Never even knew Ford had V codes, but I'm new to Diesels. I'm subscribing to this one.
Old Aug 16, 2013 | 05:48 PM
99ExpyProblems
Same symptoms as yours I think...
Old Aug 16, 2013 | 07:14 PM
mustang_309's Avatar
mustang_309
What was your ICP reading while cranking? And what are your ICPV's at KOEO?
Old Aug 16, 2013 | 07:27 PM
egregg57's Avatar
egregg57
I don't know yet. The shop has not got that far.
Old Aug 16, 2013 | 07:40 PM
mustang_309
With it dying the way it did I wonder if the HPOP or IPR died.
Old Aug 16, 2013 | 07:58 PM
m-chan68's Avatar
m-chan68
IPR valve.
Old Aug 16, 2013 | 08:17 PM
egregg57's Avatar
egregg57
Originally Posted by m-chan68
IPR valve.
I hope it isn't the Low Pressure Oil pump. Outside estimate is about 1500.00. Probably less. I am not as familiar with the IPR.
I can search it, but if you have the time M, can you give me the short and dirty?
Eric
Old Aug 16, 2013 | 09:06 PM
egregg57's Avatar
egregg57
Did some searching. I now understand the who what where when why and how. Now got to get at it and prove it. What would be the expected cost to replace the IPR?
Had to fix my wife's car (790.00), stepson's car (1325.00), and had some astronomical Vet bills (1100.00). The bank account has taken a beating this month. Not in the best position! And we don't do credit!
Eric
Old Aug 16, 2013 | 09:13 PM
mustang_309
The list price for the part is 290 bucks but you can get it through tousley ford parts for 175, AutoNation Ford White Bear Lake Parts (previously Tousley Ford Parts) not sure what the labor cost would be.
Old Aug 16, 2013 | 09:16 PM
egregg57's Avatar
egregg57
Yup, used Tousley to get my parts for the Head job. Like them a lot. Thanks for the input, Mustang. I appreciate it.
Eric
Old Aug 16, 2013 | 09:31 PM
mustang_309
Anytime bro, lets hope that's all it is.
Old Aug 16, 2013 | 09:33 PM
egregg57's Avatar
egregg57
One can hope! :-)
Old Aug 19, 2013 | 09:28 PM
egregg57's Avatar
egregg57
Shop is finally able to get into my truck Tuesday. Hoping to post (good) update tomorrow. We'll see! Hoping for the best!
Old Aug 19, 2013 | 09:49 PM
BLADE35's Avatar
BLADE35
This Link is Not working for me today it has in past somethings changed
work for you guys??
