Hi all, I have a 54 ford f100 with a 85 302 and AOD trans. The trans is almost history and I would like to go to a 5 speed. What I need to know is what later model ford I can pull a 5 speed with a flywheel and everything behind it that will work in my 54? I have a pedal assembly that I found on cpp's web site and will have to go to a 7 inch brake booster for the clutch cylinder to work on the firewall and I will probably have to use a hydraulic throw out bearing. I guess the late 90's mustang 5.0 would work but where can I find one. I am reading that it will have to be out of a v-8 so should I look at trucks and which ones came with a 5 speed? Any help would be appreciated. bill
I just happen to be selling at the Watson Lake Car show and swap meet everything that you need to put a T5 five speed behind a 302. Flywheel, bellhousing, clutch fork with bearing and new King Cobra clutch and pressure plate. I was going to ask for $300.00 for everything and I have a buddy coming for the weekend from Las Vegas that could bring it to Vegas for you. Let me know if your intrested.
