How many rear leafs in '42-'47 PU's?
Old Jul 17, 2013 | 06:57 PM
3Mike6's Avatar
3Mike6
reason I asked I bolted up a rear fender (never had them on since I bought the truck in pieces) and there's a good 8-10 inches between the top of the tire and bottom of the fender.
From other "original" side pics I've seen of these trucks, mine is much higher.
I counted 16 leafs in the rear spring pack...I'm wondering if someone in the past added some, or put on some from something else?
Thanks
Old Jul 19, 2013 | 09:44 AM
christurney77's Avatar
christurney77
I only have 10 leaves on my 46 1/2 ton.
I removed the overloads.... Don't remember how many leaves were there. Hope this helps!
Old Jul 19, 2013 | 11:01 PM
STELLA1's Avatar
STELLA1
I have 13 on my 1-ton, however I will remove a couple as there is some cracked ones near the bottom. Almost wonder if you have a 1-1/2 ton or 2 ton, the larger trucks I see around here have about that many. A pic would be handy to make a good determination.
Old Jul 24, 2013 | 07:22 PM
3Mike6's Avatar
3Mike6
Thanks Stella,
No, for sure a 1/2 ton...I think that someone swapped them out in the past.
I put in a set I had from an F1, seems to have gotten back to stock ride height.
Below are before and after the swap.
thepitshop
Jul 25, 2021 01:05 PM
white 66
1947 and Older Ford Trucks
Oct 29, 2017 11:14 PM
Al3xMac
2015 - 2020 F150
13
Sep 26, 2017 07:00 AM
Jeff and Nicolle
32
Mar 19, 2012 12:49 AM
low54
Apr 13, 2011 05:31 PM
