where is rear axle tag?? how to tell diff 3.55 or 4.10
Old Jul 12, 2013 | 11:36 PM
diesel&coffee's Avatar
diesel&coffee
As stated.. where is the tag on rear donut/axle.. Any other way to tell diff in 3.55 vrs 4.10 rear end.. Guess I could post picture. How much smaller is donut on 3.55?? ref: 1995 5 speed manual
Old Jul 12, 2013 | 11:54 PM
stainlessstroker95's Avatar
stainlessstroker95
What is the axle code on the door tag? If you dont have one of them, pop the diff cover off and count teet.
Old Jul 13, 2013 | 12:16 AM
pilgrimbizket's Avatar
pilgrimbizket
I thought you could jack the truck up and spin the tires and compare to driveshaft rotations
Old Jul 13, 2013 | 07:23 AM
fordpride's Avatar
fordpride
What RPM are you turning at 70mph ?
Old Jul 13, 2013 | 07:42 AM
tshrager's Avatar
tshrager
This is the easiest if you can't find your tag. Tag should be on one of the diff cover bolts. Also if you're going off RPM, what size tires are you running?
Old Jul 13, 2013 | 07:53 AM
diesel&coffee
A lot :-) !!!!! Thanks for all replies! Door tag says 35 - should 4:10 .. Was hoping 3:73 .. Will also check diff bolt also.. Great truck but was told it was a 3:73 and that really wasn't what I was concerned about when buying as for looking at issues..
Old Jul 13, 2013 | 08:16 AM
Tim Shultz's Avatar
Tim Shultz
Just run some 35" tires to make up for the 4:10 gears lol
tshrager's Avatar
tshrager
The only way it has 3.73's is if they were swapped. Factory didn't do that ratio in these years. So what RPM are you turning?
Old Jul 13, 2013 | 09:26 AM
diesel&coffee
Well let you know later today :-)
Old Jul 13, 2013 | 11:15 AM
diesel&coffee
RPM at 70 +/- 2400 ... at 60 +/- 2100..
How hard to replace drive shaft seal??
Old Jul 13, 2013 | 11:19 AM
fordpride's Avatar
fordpride
You have 4.10
The rear axle is a sterling 10.25
Old Jul 13, 2013 | 12:30 PM
427 fordman's Avatar
427 fordman
I'm sure Mike meant sterling 10.25. Are you talking about the seal in the trans or the rear end?
Old Jul 13, 2013 | 01:46 PM
fordpride's Avatar
fordpride
Yup I meant 10.25
Fat sausage fingers and keyboards don't get alone
It's corrected
Old Jul 13, 2013 | 02:40 PM
diesel&coffee
Rear axle/driveshaft seal.. pinion seal - I know it will be said has to oretty good inch pound torque for bearing life.. I know a lot of dodge cummins truck that say just mark the bolt/shaft, count threads, put in new crush washer and add 1/8 - 1/4 turn.. :-)...
ps: My other truck is a 2004.5 2500 5.9L 48RE with $$$ TRANS
Old Jul 13, 2013 | 02:49 PM
fordman67's Avatar
fordman67
No.replace it.when you reinstall the nut.blue lictite it and only torque by hand.NO impact...i use a standard length ratchet (12" or so) total and tighten it as much as i can.that way you can never crush the sleve any more than ut was before.done hundreds like that with zero comebacks.
