truck down til i find this part
Old Jul 10, 2013 | 08:08 AM
kupiec20's Avatar
kupiec20
long story short is that i need a HPOP tank cover for my 1996.
ford no longer makes it. i have a oil leak out my sensor hole.
ive checked all bone yards and nothing out there.
ty
Old Jul 10, 2013 | 04:02 PM
pilgrimbizket's Avatar
pilgrimbizket
Have you tried LMC, or bronco graveyard
Old Jul 10, 2013 | 04:13 PM
madpogue's Avatar
madpogue
This is the reservoir we're talking about? The hole for the sender for the "gauge" on the dash? Would it be worth drilling/tapping it to a size larger and just putting a plug in it? Any port in a storm....
LMC and Jeff's have very few (if any) diesel engine parts, since they cater more to the generic pickup/Bronco crowd. I'd be checking the classifieds here and on the other truck forum sites.
Old Jul 10, 2013 | 04:35 PM
kupiec20's Avatar
kupiec20
ok. no luck at LMC. yes we are talking about the reservoir and the leak is where the sensor is. i tapped it out with a bigger hole about 6 months ago and was good for a bit but its back.
Old Jul 10, 2013 | 04:43 PM
ReBilld's Avatar
ReBilld
Talk to Clay at Riff Raff. He may know of some.
Old Jul 10, 2013 | 05:52 PM
ProjectDually's Avatar
ProjectDually
Have you checked a pull it yourself or salvage yard? Anything from 94-97 should be the same part your looking for.. Do you have a picture of the part? Is there a seal or an o-ring that might be broken in that area?
Old Jul 10, 2013 | 10:59 PM
madpogue's Avatar
madpogue
Did you put the same sender back in, or did you put in a plug? If it's the same sender, bigger hole, no surprise it's leaking. Maybe tap it out to the same size as the fill/check plug on top and use one of those plugs. You got nothing to lose, if you're fixin' on replacing it anyway.
Old Jul 11, 2013 | 05:41 AM
kupiec20's Avatar
kupiec20
so your sying to eliminate yhe sensor all together and just have two plugs?
Old Jul 11, 2013 | 07:50 AM
madpogue's Avatar
madpogue
For the time being, anyway. At least it'll buy you time to drive the truck 'til you find a replacement reservoir.
bryanlindborg600's Avatar
bryanlindborg600
any chance you could use a heli coil, or is your "newly" tapped hole too big already? just a thought..
Old Jul 11, 2013 | 08:13 AM
DIYMechanic's Avatar
DIYMechanic
Let me check tonight. I think I may have a spare res I could get to you. PM me tomorrow if you don't hear from me by lunch time.
Old Jul 11, 2013 | 09:02 AM
superduty4x4's Avatar
superduty4x4
If Nate comes up empty handed I might be able to help out. I have a guy saying he wants to buy the long block I have but if he's not worried about the HPO res lid I can pull it for you.
Old Jul 11, 2013 | 09:32 AM
kupiec20's Avatar
kupiec20
thanks guys...
Old Jul 11, 2013 | 07:14 PM
flaboy63's Avatar
flaboy63
I have one off a E350 If you PM me your address I will send you the tank just let me know, John
Old Jul 11, 2013 | 07:59 PM
fordpride's Avatar
fordpride
What year E350?
