rear brakes - rebuild and questions
luckily a complete hardware rebuild kit is only ~$20 on rockauto, so I think i'll go that route and just be done with it, but if it wasn't so darn expensive, it'd be nice to go with discs on the back, but the wallet definitely doesn't support the ~$800 conversion kit right now.
so, sticking with drum brakes, are there any special tools (other than lots of patience and safety glasses) required to do the job? I've rebuilt smaller car drum brake systems in the past, but these suckers are huge compared to those.
here's some pictures of the setup as it stands now:
left side, showing busted cable (is this cable to actuate the self-adjuster, or is it somehow related to the e-brake?)
left side adjuster - looks like its on backwards to me, but that's based on nothing - I figured i'd sort it out with the shop manual once I get to work on it.
right side adjuster - oriented the same way as other side.
neither of the adjusters moved worth a darn by hand though and the cylinders looked old and cruddy as well. I couldn't test them as I've already removed the leaking brake line back from the ABS unit back to the rear axle (well, sort of. that's another question - but lets stick to the drums for now)
anyway - the kit below appears to have all the parts needed to rebuild both drums, so with it and some new cylinders, I should be good as new, right?
now the final question - the brake line going from the ABS unit to the rubber hose mounted in the rear frame was quite rusty and looks like its been replaced in sections previously, so i'm yanking it out and replacing it with one piece while I have the midship fuel tank out. the fitting came out of the ABS unit easily, but the one in the rear fame (where it connects to the rubber hose down to the axle, right in front of the rear fuel tank) is stuck real good. its soaking in quite a bit of PB Blaster as we speak, but I've already stripped all the wrench flats off of it and have had no luck with vise grips or a hammer and chisel. any other recommendations?
i'd rather not ruin that rubber hose as it seems to be in good shape and integral to the distribution block down on the axle, which in turn seems to be magically fastened to the axle. i'm thinking of cutting the brake line just above the stuck fitting and sticking an easy-out in the resulting hole if all else fails. any other suggestions?
EDIT: oh - and one more question - all SRW axles have 3" wide brake shoes, right? it looks like duallies have 3.5" wide ones and SRW's have 3"ers, but I didn't measure this last night and want to make sure I order the right kit from work today... if there's a chance of crossover, i'll hold off, but if it was all one way or the other, i'll order today...
any chance the F-Superduties has rear discs that could be swapped over to our trucks?
fiddling with all those stupid drum brake springs - here I come!
Richard
EDT: if you get a 99-04 axle you can convert the hub so you dont have to change wheels. But the down side is that the brakes are smaller.
That is what I ment by "converting" the hubs.
Richard
Do they fit the 8x6.5" OBS bolt pattern?
Or did you buy some new wheels?
Also...what modifications need to be done to the suspension?
I am unfamiliar with the 05 axles...whether or not they are the same D60/10.25 or if the new trucks are a new setup.
Intrigued because I want all discs, but for our era doing some half-a$$ job conversion kit with single piston calipers orrrr doing the F-superduty axle conversion with dual piston calipers, but also having to use the hydroboost and its a wider axle i believe.
And JP sorry to hijack! I plan on just keep using the current setup until i find a time/money worthy conversion. I had the PO replace all of the brakes before i purchased so i have yet to touch them.
