ICP
Old Jul 9, 2013 | 03:36 PM
97_Stroke's Avatar
97_Stroke
ICP
Okay,HPOP Replaced, IPR Replaced, Truck didnt want to start without a little help of starting Fluid, Then didnt want to idle. Now it will start after turning over a good little while, and thats giving it throttle. I unplugged the ICP, and then tried starting and it started quite easily, but was chugging and had a very rough idle. On the start up I noticed that I only was getting smoke from the passenger side or right bank on start up.
Old Jul 9, 2013 | 08:05 PM
F350-6's Avatar
F350-6
How can you tell which side of the motor is sending white smoke out the exhaust?
How much has it been driven since all the change? You've got to work the air out of the oil rails in the head before it will start up like normal again. Smoke and rough idle are fairly normal after opening up the HPO system.
Old Aug 3, 2013 | 06:38 AM
97_Stroke's Avatar
97_Stroke
Uh true duals
Old Aug 3, 2013 | 06:42 AM
F350-6's Avatar
F350-6
Originally Posted by 97_Stroke
Uh true duals
Not running a turbo?
Old Aug 3, 2013 | 07:17 AM
97_Stroke's Avatar
97_Stroke
Lol, this is true. However it only seemed to smoke on the right bank everytime it started. Led me to believe it was only the right bank.
Old Aug 3, 2013 | 07:19 AM
97_Stroke's Avatar
97_Stroke
Well it was only coming out of the right tail pipe hows that
Old Aug 3, 2013 | 07:27 AM
oldbird1965's Avatar
oldbird1965
I drove 160 miles once before it would start and run normal.
Old Aug 3, 2013 | 07:31 AM
97_Stroke's Avatar
97_Stroke
I posted another new thread about the idm. We did a buzz test on the injectors and found one bad, as a matter of fact it was injector 1 . After replacing it the issue still wasnt fixed. Thats when we threw on another idm just for the heck of it. That fixed it right up
BigRed7.3l
Jan 14, 2014 03:57 PM
maximumsportz
Nov 18, 2007 09:36 PM
zaconizer
18
Nov 16, 2007 02:10 AM
charlie calcote
Oct 30, 2004 02:52 PM
