Sponsored by: Auxito
Ticking
Old Jul 6, 2013 | 02:55 PM
1999fordpiece's Avatar
1999fordpiece
Ticking
Strange ticking only at idle. not sure if its a lifter or what any ideas on how to diagnose?
99-4.6-2wd
appreciate the help!
Old Jul 6, 2013 | 06:48 PM
vaper's Avatar
vaper
First thing I would check is the passenger side exhaust manifold for broken studs
Do a search for "Triton engine noise/knock/tick"
Ignore all the 2004 and later hits as they are mostly
cam phazer related
Welcome to the forum!
edit....check for loose spark plugs
Old Jul 6, 2013 | 10:29 PM
1999fordpiece
I have checked studs and spark plugs and all is tight and good.the noise is strange because it only happens every now and again and only low rpms. in my experience a lifter tick doesnt come and go as it pleases.
Old Jul 7, 2013 | 01:38 AM
BFTUFF's Avatar
BFTUFF
It may be that the lifter is just starting to go and is noticeable only at idle. Once throttle is increased and oil pressure rises, the lifter may hold enough to pick up the slack. I have a bad lifter in 98' It started out only noticeable when the engine was cold. After a few minutes (as it warmed up) the ticking suddenly stopped. 2 years latter it ticks all the time especially under load. I have a new one ready to install once I find the time to do so. The follower may be bad also and may need replacing to, once I get in there? Looks like a PITA to remove the valve cover, hope I can get around the AC lines without disconnecting them. It just has to make it through the summer because I have newer 03' 5.4L engine to drop in it's place.
Old Jul 7, 2013 | 01:47 AM
bla614's Avatar
bla614
I had a similar thing happen to my 2001 f-150. Turns out it was the timing chain tensioner. 247k miles she runs like a new truck
Old Jul 8, 2013 | 03:29 AM
BFTUFF's Avatar
BFTUFF
Did you install an entirely new tensioning system while you had the front cover off?
Timbers
2009 - 2014 F150
Dec 29, 2017 06:40 AM
offroadnt
Modular V8 (4.6L, 5.4L)
Feb 23, 2014 09:06 AM
Old Speed
1983 - 2012 Ranger & B-Series
Jun 21, 2005 07:50 PM
elemint
Oct 12, 2004 06:45 PM
dougas
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 8, 2003 02:09 PM
