292 alternator?
Old May 19, 2013 | 08:57 AM
schoo's Avatar
schoo
292 alternator?
The alternator mount/bracket on my 64' f250 4wd 292 was Mickey moused and I would like it to be a little more stock any body have a pix to help out
Next ? I have an alternator off a 65' will that work with a 64' voltage regulator or should I use 65' reg
I think the wiring is the same?
Roy
Old May 23, 2013 | 07:30 PM
charliemccraney's Avatar
charliemccraney
You can get a real nice cast aluminum bracket from John Mummert.
Anyone who knows what they're looking at will know it is not stock, but it does not look out of place.
Old May 23, 2013 | 09:13 PM
schoo's Avatar
schoo
Yes I saw them thanks Charlie I making them out of other ford parts
Roy
Old May 25, 2013 | 10:15 PM
schoo's Avatar
schoo
got the alternator installed, now I need to move the water pump pulley it doesn't line up to the crank has to be shimmed out about a 1/4"
Old May 25, 2013 | 10:18 PM
schoo's Avatar
schoo
yes one wire plus idiot lite
bracket is made from ford parts
Old May 27, 2013 | 12:35 PM
daveengelson's Avatar
daveengelson
If not sure the pulleys are correct for the 292 application then may be able to run a search on the crank and water pump pulley to determine if correct. May need to go from single to multiple groove pulley. Had similar problem and found the crank pulley salvage from the bone yard did not match the water pump pulley. If able to get the P/N off both should be able to find the matching pulley for the 292. In my case I did not have a clue so I went to Ebay and ran a search with the particular P/N and read the item description and found the water pump was correct for the engine but the crank was not. Found a seller, m. Goodson, and email where he provided a list of options and if he did not have the item on auction he could list the item(s) on ebay for me to purchase. For $20 fixed the problem of aligning the belts. If the alt., and or, brackets have been modified or altered then finding a solution for aligning the belts can become problematic??
Old May 27, 2013 | 08:18 PM
charliemccraney
If you use a truck pulley on a car pump, it would put the groove about 1/4" farther back, if it mounted at all. The pilot hole will also be larger on the truck pulley than the pilot on the car shaft.
If they are matching components, then there should be no misalignment, and you will need to investigate further for the cause.
You might knock that burr off the alternator pulley to avoid possible problems.
Old May 27, 2013 | 08:52 PM
schoo's Avatar
schoo
Did not notice the burr on the alternator pulley
Thanks for the info on the water pump will ck it out
There were two burrs on the pulley
svolpone
Dec 9, 2014 03:55 PM
1960 F100
Aug 28, 2007 09:54 PM
mollmanhj
Oct 16, 2004 09:50 PM
Cowboy_tx
Oct 10, 2002 02:19 PM
