6.0 smokes, burns eyes, runs good. no codes Help
Old Apr 16, 2013 | 11:20 AM
Johnsdeere's Avatar
Johnsdeere
Help, have a 03 6.0 with 130,000 miles. Truck smokes when idling/fast idle grey color, smells like fuel and stinks like fuel burns your eyes. No codes on the AE, power balance looks good on the AE as well. Runs and starts good. Turns over good but I suspect a possible leaking injector. Turbo has been replaced and was bad also, and it had a plugged converter that is removed now. Truck does not smoke blue like it did with the Turbo bad. EGR has a block off kit and the cooler is removed. Oil cooler replaced, ICP replaced, EBP replaced both sensor were bad. I did not see bubbles in the filter housing when testing. I put all new orings and copper seals on the injectors when I replaced HG and torqued then to spec. 4 of the injectors are ford remans. I pulled the manifolds and ran it to try to find a smoking cylinder, drivers side looks clear and not burning eyes bad, passenger side all the cylinders look similar with light smoke, but they do let out a spark now and then out the heads when running. Driver side has no sparks. Smoke burns your eyes very bad and you cant hardly breath like fuel.
So since I can confirm that it is the passenger side, what now. I cant really find a cylinder that smokes a whole lot worse than the others. Possibly the second one smokes more but its really hard to tell. I suspect fuel since it burns your eyes so bad. What could cause the whole bank to be smoking, over fueling. Do I have a leaky injector possibly. Do I pull the injectors and have them tested? Where do I go now. No other problems other than smoking bad and burning eyes? Can the dealer run a better power balance than the AE? I'm at a loss. Help!
Old Apr 16, 2013 | 02:31 PM
BLADE35's Avatar
BLADE35
Does smoke go away when warm???
Lets Not rule out turbo or a sensor that controls turbo calibration yet
Use the AE to do an injector Buzz test
What the FICM AT 48 volts KOEO and running??Also under load??
When you did Bubble test did you have Fuel Over the standpipe in filter housing???
Also the Bubble test only tests Fuel side of injectors
You may have weak or dirty spool valves
If you have a DVM Ohm the inject Coils each inject has 2 coil (the Inject Buzz test is also a check for this but dont hurt to double check)
Could also be Inject harness so Ohmit out
Sounds like you have narrowed down to passenger side
Warm truck to normal temp and post
ICP
ICPV
IPR%
BARO
Boost
MAP
MAFV
RPM
Volts
FICM MP
Each sensor needs 3 values posted per each for---KOEO--Low Idel---High Idel(2500rpm)
Also Post ECT & EOT at the time of the Test
Good Luck!!
Old Apr 21, 2013 | 08:12 PM
Johnsdeere's Avatar
Johnsdeere
Update, checked for bubbles again in the fuel filter housing and nothing. I pulled the 4 injectors in the bank that it smokes from and did not see anything alarming. I have talked to a ford diesel tech and a international tech and neither have an idea. The ford dealer did not want to waist my money trouble shooting it. I am going to look for some place that can bench test the 4 injectors I pulled out to rule them out. All four are recent ford reman injectors. I have new heads, oe gaskets, studs, egr delete kit, oil cooler replaced, turbo replaced, icp replaced, ebp sensor replaced. The degas bottle hold pressure for days. I get grey/white smoke that stinks like fuel bad and burns your eyes but starts and runs great, good power too. Smoking seems worse when its warm and at idle. So far I have stumped every one. What would make it smoke on one bank?
Old Apr 23, 2013 | 08:58 AM
Johnsdeere's Avatar
Johnsdeere
Sent my Injectors for testing
I sent 4 of my injectors from the left bank into Huckstorf Diesel Pump & Injector Service, Inc in Franklin WI for testing yesterday. Testing costs $35 a piece. I am crossing my fingers they find a bad injector. These injectors are about 2 years old Ford OEM remans, but one does show signs of leaking past the copper seal on a tear down before this time. All were sealing good this time. Maybe its possible previous combustion leaking past the copper seal did injector damage to this injector or another in this bank. That being said all 4 were sealing good this tear down. Should know later today the test results.
Old Apr 23, 2013 | 07:32 PM
Johnsdeere's Avatar
Johnsdeere
Test results
Back to the drawing board, all 4 injectors test really good, no problems... they are shipping them back. Only recommendation their tech had was to have the truck flashed with the newest update.
Question does the FICM have a circuit for each bank? Just wondering if it could be a bad board in the FICM causing the smoking and still start and run good. FICM does test good for power.
What else could possibly cause smoking? Worse when warm. Grey and stink like fuel burn your eyes? I have to be missing something? Anyone?
Old Apr 23, 2013 | 09:27 PM
chewedtoothpick's Avatar
chewedtoothpick
I may not be a guru like Blade, but have you tried a compression test to make sure that the valves are properly seated?
Old Apr 23, 2013 | 09:43 PM
BLADE35's Avatar
BLADE35
Well Injectors 4 are Good and I bet they ALL Are
Was this plugged Coverter Recent??
You need to refer back to my first Post and get all those Numbers
You may have a Turbo Problem and its not getting any Air to properly Combust and Smells Like Diesel Fuel
Old Apr 23, 2013 | 10:00 PM
BLADE35's Avatar
BLADE35
Guess its going to be a Day or two so you can put it back together
Then Test Everything Before teardown
coco deetercus
Sep 2, 2015 11:40 PM
carrcreekcaller
Aug 13, 2012 04:06 PM
PowerstrokenAL
Oct 15, 2010 07:33 AM
teardropty
Jun 28, 2010 10:42 PM
Dbailey
13
May 31, 2010 11:55 AM
