Off Topic - Luck
Old Apr 6, 2013 | 08:56 PM
4tl8ford's Avatar
4tl8ford
Off Topic - Luck
I was in the basement tearing down a transmission - when I got as far as I wanted I started putting stuff away when I decided to wash some parts - I was scrubbing away at the parts in the sink when I felt a cold spray - It was either the dog with a squirt gun ow the water heater that was right behind me - I started looking at the water heater and the supply line nut at the water tank had split - I shut everything down and was going to wait until tomorrow when I remembered I had a slightly used one from my old tank - Wrench, wrench, wrench and it is good as new
If I hadn't been down there tonight I would have had a new indoor pool
Just had to share something good.
Old Apr 6, 2013 | 09:28 PM
Doc's Avatar
Doc
Yep. You got lucky! If that had happened to me, I would have been on a cruise ship or a spaceship somewhere watching my house float away on CNN. I opened the door to my basement years ago and saw a swimming pool one morning. My deep freezer was running very nicely as it floated by me still plugged in!!
Old Apr 6, 2013 | 09:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You dodged a bad one for sure, Dick!
Old Apr 6, 2013 | 09:52 PM
51dueller's Avatar
51dueller
At least all the safety features didn't fail at once and it went through the roof all Mythbusters style.
Next you'll be finding an old silver dollar under the couch
Old Apr 7, 2013 | 06:52 AM
4tl8ford's Avatar
4tl8ford
I'm still trying to figure that one out - I had been in and out of there at least 3 time in a 20 minute period and hadn't seen a thing - I had even dropped a paper towel on the floor that I hadn't picked up yet - No sound just cold water (Better then hot) on the back
Oh did I mention that it was about 9 0:clock when it happened, On a Saturday night?
Tim The Toolman was looking over my shoulder
Old Apr 7, 2013 | 07:13 AM
brkellogg's Avatar
brkellogg
You should go buy a lottery ticket!
Old Apr 7, 2013 | 08:04 AM
DR Smith's Avatar
DR Smith
one reason I shut the water off at the street,when we go away,
Old Apr 7, 2013 | 08:05 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
No, it's too late. He wasted all his luck on a water heater.
Old Apr 7, 2013 | 08:07 AM
EffieTrucker
I thought I was the only one that did that. I also turn off the power to the shop. If the house burns down I only loose my furniture, clothes, etc. If the shop burns down I loose my flathead and my tools.
Old Apr 7, 2013 | 08:52 AM
oldmerc's Avatar
oldmerc
oldmerc
Yes very lucky indeed . I also turn off everything that does not need to be on when I'm not using it . And yes I drain my compressors every day.
Old Apr 7, 2013 | 09:02 AM
qmanconfused's Avatar
qmanconfused
I was once at a home of a friend of my mother-in-law's house installing a gas, free standing heater unit. as my partner was behind the dryer tying into the gas supply the washer water supply started leaking at a rate that would have scared the 88 yr old woman to death....if she would have heard it at all. I went back to the hardware store and bought the parts I needed to fix the water leak....about $25. then my partner/helper moved the washer dryer out to fix the problem and put everything back the way it should be. we spent about an extra 1 1/2 hr to fix the problem. when we were about to leave I handed her the bill for the gas stove and told her exactly what I had to do to correct her water leak. she was so thankful and happy that we had taken the time to help her out....and greatful too! she gave me $5 to split with my partner. that's a total net loss of about a hundred bucks.....damned if you do....damned if you don't
Old Apr 7, 2013 | 09:34 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Great timing Dick!
Yesterday I was working in the garage and I decided to tap into a water line so I could run a line over to the garage fridge for the icemaker. I have a 3/4" supply line in the garage with a loop from an old water softener system. The 2 ends were the tank used to be are just hooked together. I pulled them apart and slid the valve a little ways to confirm I had water. Sure enough, good flow of water AND a valve that wouldn't shut off!
I toyed with it for a bit and then decided to hook the pipe back together (not an easy task with water flowing) I finally got it back together (along with a decent soaking). Yup, I turned my garage and workbench into a swimming pool. I'm a rocket genius!
Bobby
Old Apr 7, 2013 | 10:03 AM
ALBUQ F-1's Avatar
ALBUQ F-1
After two or three relatives having toilet supply hoses blow while on vacation, I'll shut them off at the wall valve. Especially since the water pressure at my house is 90 psi!!
Old Apr 7, 2013 | 01:49 PM
yamagrant's Avatar
yamagrant
Originally Posted by bobbytnm
Great timing Dick!
Bobby
That's why I buy ice
sunuvabug
All Things Towing
Dec 15, 2016 02:51 PM
RA31925
All Things Towing
16
Oct 26, 2013 07:59 PM
82'Stepside
Kansas Chapter
26
Oct 25, 2009 10:44 PM
AndysFords
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Feb 2, 2007 11:28 AM
Greywolf
All Things Towing
Oct 29, 2006 11:34 AM
