It looks like it is designed to work with engines built in the last decade that originally came with drive by wire electronic throttle bodies so pretty much GM 5.3/6.0, Ford 5.0 coyote and Dodge 5.7 hemi etc.
While you probably could make it work with a carburetor but would require assembling a microprocessor and circuit board to take the pedals signal to actuate a small linear actuator attached to the carburetor linkage.
A simple cable setup is much simpler and easier IMO.
