460 into f100
Old May 31, 2003 | 12:41 PM
custom_truker's Avatar
custom_truker
460 into f100
You guys think it is possible to get a 460 cubic inch v8 into a 78 f100 with out a whole lot of modifications? The truck has a 300 inline six in it riht now, but I might be able to get my hands on a 460 to try and drop in there. What sort of modifications might be needed? Would stiffer springs be in order, as well as stronger drive train parts? What kind of new transmission would be best? Anything I can find at a junkyard? I am on a limited budget because I am in college and don't have a whole lot of extra money. Anyway, thanks for any advice.
Old May 31, 2003 | 01:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
460 into f100
Take a look around, this modification has been discussed a few hundred times Lot's of experience and info here.
Old Jun 1, 2003 | 02:33 PM
Rocking M's Avatar
Rocking M
460 into f100
I'm in the slow, very slowy, process of doing the same thing. How far along are you or are you just considering this? PM me and we can discuss it. Laptop Geek is another member who has completed this project. He's a really helpfull guy.
Old Jun 3, 2003 | 02:39 PM
laptopgeek's Avatar
laptopgeek
460 into f100
Custom_Trucker ---
See my web site at
<http://www.beedzncomputers.com/truck/truck.html>
for some pix of this conversion. Keep in mind --- once the transfer is complete - it's VERY dangerous....VERY powerful combination....
Before you do the swap, you might want to consider buying some stock at GoodYear.....
Thanks for the Kudos, RockingM - good luck with your swap - I've more pictures AND SOUNDS posting to the web site soon...
Old Jun 3, 2003 | 03:49 PM
Racerdave's Avatar
Racerdave
460 into f100
Hehe.... Sounds like your in for a lot of fun work.... Good luck!
Old Jun 3, 2003 | 11:45 PM
Colossus's Avatar
Colossus
460 into f100
Try not to get pulled over too often.
Old Jun 4, 2003 | 01:22 AM
Racerdave's Avatar
Racerdave
460 into f100
Yeah, no kidding.... And you might want to make sure the front brakes are really good, your front brakes do 90% of the stoping, and with the added weight.... I am not sure how much more it will weight, but just a thought.... Hey I hope I am not butting in, but I was wondering how much a job like this would cost? Including all of the modifications?
Old Jun 4, 2003 | 01:37 AM
LxMan1's Avatar
LxMan1
460 into f100
It's not too bad, I did mine, by myself, in about a week. I went from a 351w to a 77 460. If you don't use truck manifolds or headers, you will have to notch the frame for the passenger side manifold. All of the motor mount, frame mount holes are already in the frame. If you are getting the motor out of a car, the tranny is longer and will not accept the truck mount. I had to shorten my driveshaft 2 3/4". You must have 460 truck frame mounts and motor mounts. Other than that, it's just bolt and go.
Jimmy
Old Jun 4, 2003 | 11:54 AM
ExplorerRon's Avatar
ExplorerRon
460 into f100
I've been considering this swap myself. I have all the parts but I don't want to go overboard. I have a '92 5.0 out of a Mustang GT in it (1977 F-100) right now but it does need a bit more power. I picking up a new rear-end today in hopes of helping the pep.
Ron
Old Jun 4, 2003 | 12:57 PM
Mil1ion's Avatar
Mil1ion
460 into f100
As soon as the search feature will search 3 letter words, there will an unlimited amount of info available.
Old Jun 4, 2003 | 01:24 PM
laptopgeek's Avatar
laptopgeek
460 into f100
Hey Mil1ion, would you send me a private email, I need to ask you somethin' ... thanks man...
Old Jun 4, 2003 | 03:24 PM
Racerdave's Avatar
Racerdave
460 into f100
Does anyone have an aprox cost of everything to do this ?
Old Jun 4, 2003 | 03:32 PM
laptopgeek's Avatar
laptopgeek
460 into f100
RacerDave ---
I guess cost depends on how deep you want to go with the project. I had my 460 blueprinted / balanced / bored and added a lot of hot rod stuff to the motor. I would say roughly a few thousand ( and this includes the rebuild ).
Cost also varies with what part of the country you're in. Labor rates down here in the southeast are a lot less than some areas in the the northeast.
Before I started the project I did a LOT of shopping at summit / jegs / and L&L....
Old Jun 4, 2003 | 03:38 PM
Racerdave's Avatar
Racerdave
460 into f100
Hmm.. so aprox 2-3k? I was planing on buying a EFI 460 and then doing a rebuild, not adding much except ram air and Headers.
banjopicker66
21
Feb 26, 2015 03:10 PM
banjopicker66
Feb 22, 2015 09:33 AM
banjopicker66
Feb 22, 2015 05:48 AM
Jeff's Secretary
Engine Swaps
Nov 1, 2007 09:40 AM
54_Ford_F100
Nov 2, 2004 01:44 AM
