Power mirrors don't work in all directions? Also shifter question
Old Feb 20, 2013 | 10:43 PM
90pioneer's Avatar
90pioneer
Have a 2003 F250 I just flew across country to pick up.
The power mirrors don't work in all the directions. Is there an easy fix for that? It happens on both sides.
Also the gear shifter (automatic trans) seems to have more play in it than the other trucks I've had. It selects gears just fine but you can wiggle it around. Any idea?
Old Feb 21, 2013 | 05:31 AM
hammer65's Avatar
hammer65
I had that problem on the passenger side while in Florida. The mirror would not work up and out, It would work in and down.
I took the switch apart, but it only worked one time correctly after I closed it back up.
Picked up a new switch at Ford Dealer and all is well.
Shifter: There are a couple of bolts under the dash, that get loose.
Old Feb 21, 2013 | 06:52 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Yeah a new switch will fix the mirrors, been there done that.
Old Feb 21, 2013 | 07:24 AM
F-250 Super Duty's Avatar
F-250 Super Duty
Had the same problem. New switch solved it for me too.
Old Feb 21, 2013 | 09:01 AM
Crashman927's Avatar
Crashman927
You can find switches on ebay for under $15.00. Or you can try Rock Auto Hope this helps.
Dorman 901 319 Switch Mirror | eBay
Old Feb 21, 2013 | 10:32 AM
jeffreyt's Avatar
jeffreyt
Yeah, just change the switch. Tried to fix mine to no avail. $30 at my local stealership, cheaper online.
MikeRizz
6.4L Power Stroke Diesel
Apr 19, 2021 02:18 PM
DavidnSusan
Feb 26, 2015 07:40 AM
pecker1951
Nov 4, 2014 10:41 AM
biker
May 25, 2010 07:06 PM
357fhp
Apr 27, 2007 11:39 AM
