Water in exhaust 03 Expedition
Old Feb 18, 2013 | 06:56 AM
chron1410's Avatar
chron1410
I recently changed a couple coils due to error codes and noticed water in the plug housing. I tried to dry it out best I could but then it's now coming out of the exhaust. Additionally, it's running rough and burning gas at an alarming rate. I been having this issue for some time and even took it to the dealer. It ran good for a couple months and started having pretty much the same issues. Any ideas.?
Old Feb 18, 2013 | 07:26 AM
red85k100rs's Avatar
red85k100rs
water or antifreeze?
Old Feb 18, 2013 | 08:21 AM
chron1410's Avatar
chron1410
that's a good question...It doesn't appear to be antifreeze. Is there a difference?
Old Feb 20, 2013 | 09:26 AM
red85k100rs
Antifreeze would come from the cooling system.
Water would come from rain, snow melt, car wash etc.
Old Feb 20, 2013 | 06:01 PM
sboychuck's Avatar
sboychuck
The catalytic converters in the exhaust system turn exhaust hydrocarbons into carbon dioxide and H2O (water). So, if the liquid is clear coming out the exhaust, it may just be the converters doing their job. Coolant has a very sweet and distinctive smell. If you have a lot of hydrocarbons due to a rough run condition, the converters may be working overtime and creating a lot of water. Try and get the rough run condition fixed ASAP, as the converters can get clogged, and then they need to be replaced. They are expensive. Probably more expensive than fixing the rough run condition. Hope this helps...
Old Feb 20, 2013 | 07:52 PM
red85k100rs
but would that explain
Old Feb 20, 2013 | 10:08 PM
sboychuck's Avatar
sboychuck
OK, so you said you had water in the plug housing. If it was straight water, probably from car wash, rain, etc. If you had coolant, that would be from a heater or by-pass hose. Both run along the intake manifold and have caused coil failures on the 5.4L. You also said you have water coming out the exhaust, that is why I brought up the converters. You say it is running rough and burning up fuel. Just because the check engine light is not on, does not mean there are no codes. Get it somewhere and get a code reader on it. You could have a bad injector that is stuck open. If you do, it could hydraulic your engine. I have seen it happen before. Sounds like something is making it run rich, which could also cause your converters to fail. First stop is to a shop that can diagnose the rough run condition. I think the water coming out the exhaust is just a by-product of the converters doing their job. Hope this helps...
Old Feb 21, 2013 | 08:22 PM
chron1410's Avatar
chron1410
thanks for the advice...makes sense to me. I'm gonna go get a diagnostic and go from there.
ztekdesign
Aug 17, 2010 09:23 AM
jeff303
May 7, 2004 08:35 PM
mechdeclined
17
Oct 1, 2003 08:51 AM
holt132
Aug 20, 2002 02:54 PM
edgarpoe
Nov 13, 2001 11:50 AM
