Water in exaust
Water in exaust
How much water, just drops? It is just condensation and moisture in the exhaust. Do you have an aftermarket exhaust? Stock exhausts have a pinhole in the muffler to let the water drip out but some aftermarkets don't. If it is stock, then the hole could be plugged up somehow.
95 F-150 2wd Extended Cab Eddie Bauer
4" Superlift Suspension
Gibson Cat-back on 300ci I-6
Ram Air-MSD Ignition-32 BFGs
Water in exaust
Water blowing out the exhaust, especially after a cold start is normal. You should get quite a few drops at first until the whole exhaust system is warmed up, probably 30 minutes. Even a drop or two after warm up is normal.
This is not a problem unless you do a lot of short runs. then water gathers in the exhaust and never gets a chance to cook dry. So the water causes rust. I have seen guys who put only 30,000 miles on their car over 10 years, have horribly rusted exhausts even though the car was taken care of religiously. They just never got things warmed up enough.
If your state has a smog test, a lot of them will do a test for free if your license is due for renewal, and the prinout will tell you whether the exhaust is normal.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
