rear differential for a 79 lincoln 460 into a 76 f100
Old May 30, 2003 | 10:46 PM
Rocking M's Avatar
Rocking M
I'm in the process of removing the bed from my truck. I plan to rebuild the truck starting from the rear. My reason? Too crzy to post all the info. Anyways, I was looking under the bed and the thought arose if I would need to change the rear end to make it compatible with the 460. I've been working on this truck for over a year and I'm still a novice. Can anyone tell me if a 460 will work with the current rear end of a 76 f100 that had an in line 6? How does one identify what type of rear end is currently installed? Thanks for the help.
Old May 30, 2003 | 11:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Your truck should have the good old 9" rear which will work just fine behind a 460. There should be a tag under a bolt on the differential carrier. If you find all of the numbers on that we can identify the ratio and differential type.
The Lincoln may have a 9" under it also.
Old May 30, 2003 | 11:13 PM
Mil1ion's Avatar
Mil1ion
Why would you think there is a different rear diff needed for a 460?
The only difference in the driveline is the U-Joints on the driveshaft.
The 9" rear serves every engine.
Old May 30, 2003 | 11:59 PM
Rocking M's Avatar
Rocking M
M il1ion,
I apologize for my ingnorance, however I am a novice and therefore know next to nothing. I only work on my truck as my jobs allow me, because of this I have research again and again to refresh my knowledge base. Thanks for the reply though, you are the greatest databank of knowledge on this website and since the day I joined you have helped more than anyone.
Old May 31, 2003 | 09:53 AM
mudder trucker's Avatar
mudder trucker
million you are a little off track. his truck has i-6, and probably 28 spline axels. these won,t last too long with a 460. mudder trucker.
Old May 31, 2003 | 11:29 AM
Mil1ion's Avatar
Mil1ion
The 9" came in 28 & 31.
It was my understanding that in the 70's all the trucks got 31 spline axles.
Only the 60's & early 70's the 9" were 28 spline
But I could be wrong.
Old May 31, 2003 | 11:33 AM
jcs17's Avatar
jcs17
did any of the f-100's come with 9" rears or did most? I've got an 8.8 and i was wondering if that is common or odd. I would love to have a 9" at some point but that won't come until i beef up the motor. thanks
Old May 31, 2003 | 11:44 AM
Mil1ion's Avatar
Mil1ion
Rocking M,
Have you checked the Rating plate on the door or gone under the truck and looked for a buck tag attached to one of the differential studs?
Old May 31, 2003 | 01:12 PM
tellico racing's Avatar
tellico racing
I actually have only found a 31 spline in a 2wd once. That truck was a 77 F150 equipped with a 351m or 400 ( I forget which ) and an np435 trans. It also had a 3.0:1 differential.
Old May 31, 2003 | 04:16 PM
tetraruby's Avatar
tetraruby
From what I've seen so far the later model F100's have the 28 spline count. Go to a 150 and you get 31. A F100 with a L6 also usually has a C4 while a F150 with the same motor has a C6....that's of the 78/79 flavor.
Old May 31, 2003 | 06:28 PM
tellico racing
A C4 in a truck???? never saw that before.
Old May 31, 2003 | 07:04 PM
jrsroadhauze's Avatar
jrsroadhauze
In my fomoco fleet I have a 71 Lincoln Mark 3 ( last year of the 10 to 1 compression and DOVE-C heads) The rear end has the 9 3/8" ring gear and sure trac brakes, early day abs system. The 9 3/8" pumpkin will fit with a little grinding in the 9" case. The ratios in those cars are 2.7ish to 1 with optional 3.00 to 1, some had posi. You will like the torque with this combo. I can get 1st and second gear rubber in my Mark 3 and top end around 135mph.
Old Jun 1, 2003 | 04:28 AM
electricmaniac2's Avatar
electricmaniac2
I had a 302/C4 and a 31 spline in my 77 F-100 2WD....anything's possible!
Old Jun 1, 2003 | 01:49 PM
Matts72's Avatar
Matts72
All F150's (1975) had 31 spline axles, also all F100's from 1975 and up had 31 spline axles. Prior to 1975 F100s had 28 spline axles, that does not make them weaker though. Also, most windsor bellhousing motors had C4s if they were autos. The C4 is just as tough as the C6.
Old Jun 1, 2003 | 02:13 PM
Rocking M's Avatar
Rocking M
Not sure if it was the buck tag or not, but the only tag I saw read BZC. There were some other stamps D 2SWC and 9 4 75. the latter of which seems like a date. Can anyone tell me what this is and how it will hold up to a 460?
