steering radius (or lack of) problem
Old May 29, 2003 | 10:31 PM
Todd77F250's Avatar
Todd77F250
I have a 1977 f250 supercab longbox 2 wheel drive and was wondering if bad steering radius is common for these truck. I can never seem to just pull strait into a parking spot, I always have to back up halfway in and take another crack at it. Is there any way to improve the steering radius so I can turn a little better. Thanks.
Old May 29, 2003 | 11:13 PM
Mil1ion's Avatar
Mil1ion
Yes it is normal for those years.
Btw, a Strait is a narrow body of water between 2 land masses.
Straight = Not crooked
Old May 29, 2003 | 11:20 PM
Todd77F250's Avatar
Todd77F250
Thanks for the correction, I think. Is there any way to fix this problem with the truck.
Old May 29, 2003 | 11:50 PM
Mil1ion's Avatar
Mil1ion
Does it relate more to turning to one direction than the other ?
Old May 30, 2003 | 12:21 AM
proeliator's Avatar
proeliator
On just about every old Ford I've gotten I could always get a bunch of extra radius out of it by adjusting the bumpstops. I don't know if Ford was conservative at the factory or if the po's fiddled with them. Sometimes (at least on the F-250s 4x4) you can flip the driver shock as this is the limiting factor for the bumpstop. In case you don't know what I'm referring to, its a horizontal adjustable bolt on the inner knuckle that comes to a stop on a pad on the axle.
Old May 30, 2003 | 06:57 PM
Todd77F250's Avatar
Todd77F250
It has the same turning distance in both directions.
