Power Brakes Question
Old Dec 17, 2012 | 09:21 PM
Mercmeister's Avatar
Mercmeister
Hello Again -
I am also in the process of installing power brakes in my '66 Ford F100 using a power brake booster from a '69 Ford F100. I am sticking with the original '66 drum brakes front and rear. If I plumb the front brakes independent of the rear brakes to the dual reservoir master cylinder, do I need the brake line junction block safety valve?
Thank You,
Dan M.
Old Dec 18, 2012 | 11:11 AM
pburress's Avatar
pburress
If you are referring to the proportioning valve, no you shouldn't need this, since you are sticking with drums front and rear.
Old Dec 18, 2012 | 06:47 PM
garbz2's Avatar
garbz2
No prop valve on Drum Drum. It will have the safety centering valve to activate the brake failure lamp that was stock on the lower left dash on bumpsides.
It is not necessary if you are plumbing the lines separately front and rear. Unless you want to use the failure lamp.
Garbz
Old Dec 18, 2012 | 08:19 PM
Mercmeister
Thanks Garbz!
Dan M.
Old Dec 18, 2012 | 11:57 PM
Macs1964F100's Avatar
Macs1964F100
Will a master cylinder for a 67 F100 bolt on to a 64 F100 without modifications? I would like to upgrade to a dual master cylinder with a center valve and brake warning light. Like pburress will stay with drum/drum but I do not need power brakes.
lauxg
Apr 4, 2017 08:12 AM
bill2298
Sep 2, 2015 08:41 AM
jwal1
Aug 2, 2012 06:38 PM
Voodoo66
Oct 13, 2010 09:07 PM
matt1morton
Jun 30, 2004 09:14 PM
