Sponsored by: Auxito
Installed new Monomax shocks - broke bolt
Old Dec 3, 2012 | 08:45 PM
BCHauler's Avatar
BCHauler
Just installed new monomax shocks front and back. Everything went smoothly, other than one of the lower studs on the front passengers shock snapped off as I was tightening the nuts.
Can anyone tell me are those bolts or pressed-in studs? Do I have to remove the lower control arm? Any help or suggestions is appreciated. Thanks.
Old Dec 3, 2012 | 10:01 PM
2Fords1Jeep's Avatar
2Fords1Jeep
It's a through bolt with a nut.
Old Feb 9, 2013 | 11:41 AM
BCHauler's Avatar
BCHauler
Turns out they are a press in stud with a hex head, like a bolt. Confusing and frustrating. Had to drill them out from the top after removing the control arm. Couldn't find any to purchase so used 5/16 (I think) grade 8 bolts with lock washers.
Old Feb 10, 2013 | 06:40 PM
IndySilverAnny's Avatar
IndySilverAnny
I had one snap on my 02. They were metric. Don't recall the size. Maybe 8mm? Took it to work, dug a bolt out of our bins, and bought one of the welders lunch to weld it on.
Was easier and faster than digging my welder out and remembering hw to use it.
Old Feb 10, 2013 | 08:02 PM
Bluegrass 7's Avatar
Bluegrass 7
It's a small issue but the bolts are metric and can be a little sloppy with aftermarket replacement shocks and cause noises.
I used SAE size and enlarged the holes to fit the bolt and the shocks.
The spline fit is for assembly line use tighening only on one side take less time.
Good luck.
MackGuy
Jun 20, 2014 03:15 PM
aceltx09
Aug 20, 2010 11:09 PM
madpogue
Nov 1, 2009 03:44 PM
greensocks
1983 - 2012 Ranger & B-Series
Sep 5, 2006 10:55 PM
Crystal
Aerostar
Sep 9, 2001 12:54 AM
