General Automotive Discussion
Tire shops and lug nuts
Old Nov 27, 2012 | 11:47 AM
Tom's Avatar
Tom
Had the tires replaced on my wife's Sienna last night and the tech never used a torque stick when he tightened the lugs with his impact wrench.
Pissed me off because I brought this to the manager's attention as he was doing it and he told me that it was normal. They have since agreed to replace all lug nuts and wheel studs.
Old Nov 27, 2012 | 12:57 PM
bigdaddyII's Avatar
bigdaddyII
Also a good way to warp rotors.
Old Nov 27, 2012 | 01:29 PM
Kruse's Avatar
Kruse
I've owned four Aerostars and whenever I bought new tires, the "techs" would always use a jack on the lower body seam, even if I told them not to. It would always buckle the rocker panel and that's where rust would start. I finally just got an extra set of rims, brought them my rims, had them install the tires on the rims and would put the new tires on at home.
As far as the rotors warping, that happened to me also. While I do all the work on my vehicles, I had a sudden front wheel bearing failure on my Aerostar and I limped the vehicle to an Indy shop for repair. He put on a new rotor and bearings. Two weeks afterwards, my steering wheel shook during braking. I had to use a breaker bar to get the lug nuts loose. They were put on that tight. I turned the rotor and it was warped so bad that it's now close to the minimum thickness after getting trued. Some guys just don't have a clue.
Old Nov 27, 2012 | 03:37 PM
jimandmandy's Avatar
jimandmandy
I use an impact wrench myself, but just to snug them up a little, takes practice. Then its the torque wrench for final tightening.
Since so many modern unit body cars are designed to be lifted at certain points on the rocker panel, they think all of them are. The Aerostar is BOF, right? So, they should be lifting on the frame or suspension, not the body.
Old Nov 27, 2012 | 04:34 PM
rikfish's Avatar
rikfish
I wouldn't worry about tire shops not using a torque wrench. I have never seen a single employee at any shop I have used have the training on how to use a t wrench properly any way. To qualify myself here, I will state I repaired, rebuilt, and calibrated torque wrenches for over 20 years.
Old Nov 27, 2012 | 05:56 PM
Fat Diesel's Avatar
Fat Diesel
FWIW the guys in Nor Cal at Custom Alignment in Mtn View use torque wrenches on the lug nuts. Nice digital Snap On wrench.
Custom Alignment is one of the only, ok THE ONLY shop I will allow to work on my stuff. The owner and technicians are members of the Nor Cal Shelby Club and have nice track cars themselves and care about what you bring in. Not cheap, but they do have an AWESOME "Road Force" balancing machine for the tires...
Old Nov 27, 2012 | 06:30 PM
BillC's Avatar
BillC
Kauffmann Tire used torque wrenches, at least at the one I used to go to before they left Texas.
Old Nov 27, 2012 | 06:37 PM
Tom's Avatar
Tom
Good point, but my concern isn't that they didn't use a torque wrench. They didn't use a torque stick or any sort of method to prevent their 400+ ft-lb impact gun from abusing my 76 ft-lb rated lug nuts. And if they didn't badly overtorque them I wouldn't have even cared. But they did, and that's my issue.
I don't even care how they get to 76 ft-lbs as long as it's there. Or even within the realm of reason. But doubling the specified torque is negligent and dangerou IMHO.
Old Nov 27, 2012 | 11:58 PM
ford2go's Avatar
ford2go
I rotate my own tires (not as often as I should), and these days I ask brake and tire places to use a torque wrench. I hope that they do -- most of the places try to isolate the work area 'for your safety'.
I don't know if the torque sticks are that bad, but the online trade magazines claim that they're not that accurate. Still better than nothing.
There are guys here who have said that they take a torque wrench with them, and check things out in the parking lot before they leave. Might not be a bad plan - especially if you tell them that you'll be doing it.
Hard to believe that the bosses don't watch for that kind of stuff.
hj
Old Nov 28, 2012 | 08:02 AM
19fifty4's Avatar
19fifty4
Many of the culprits are just production shops and I don't think supervision/oversight is in their DNA.
Old Nov 28, 2012 | 09:19 AM
jimandmandy
Leaving them significantly loose is actually worse. That is the usual reason for lug breakage, due to metal fatigue, and even loss of the wheel. Inadequate preload causes the threads cycle in and out of tension every revolution of the wheel. Automotive hardware is not that good, metallurgy and quality control, to start with.
You are right that close is good enough in the case of wheel lugs, and torque sticks, if they pick the right one, are adequate.
Old Nov 28, 2012 | 10:17 AM
Tom's Avatar
Tom
I believe that, thanks for pointing it out. I've overtorqued and broken a few fasteners in my time, as well have undertorqued things and had them come loose or break. I'm very picky about using a torque wrench on most things, and lug nuts are about as critical an application as it gets!
I would have been happy with torque sticks, and I would have even been okay with ~100 ft-lbs on the lugs. But double the specified torque load is where I would question the integrity of the fasteners. Perhaps I'm overreacting, but my family rides around in that van.
Old Nov 28, 2012 | 05:15 PM
jimandmandy
If the metal didnt yield, there is not much to worry about. Engineers give parts like this generous safety margins. After loosening them, where you able to run the nuts off and on easily by hand? If so, they are ok.
Old Dec 7, 2012 | 12:10 PM
cb_13's Avatar
cb_13
Dealership I work at requires the use of torque wrenches. Alot of grumbles from guys who come there after working at another dealership but the manager will not budge on it and I think if nothing else it makes the customer feel better to see guys torqueing the wheels on their vehicle. That is assuming that everyone uses the torque sticks the way they are intended and not incorrectly. We also have a road force balancer. Great way to steal work from the local tire shops when we can fix a vibration they caused.
Old Dec 7, 2012 | 06:56 PM
Fat Diesel's Avatar
Fat Diesel
You'll steal customers for life in a lot of cases.
What is a torque stick?
