Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
75 F100 rear leaf springs for 53-56 F100.
Old Sep 24, 2012 | 08:46 AM
Fomoko1's Avatar
Fomoko1
Originally Posted by yamagrant
On the M100? You'll have to send me pic's.
Since the wanted/selling thread is for ads I started this thread.
I`ll try to get pictures soon. In the mean time I`ll have a look to see how I swapped the 75 F100 rear springs into my 53 M100. I remember drilling out the rivets and bolting in the newer spring hangers, I don`t think there was much more to it.
Old Sep 24, 2012 | 05:13 PM
effie_man's Avatar
effie_man
if i remember right I drilled and bolted in those leafs on your 56
Old Sep 24, 2012 | 10:11 PM
Fomoko1's Avatar
Fomoko1
Hopefully you took some pics cause it`ll be a while before I can get to it.
Old Sep 24, 2012 | 10:32 PM
effie_man's Avatar
effie_man
As I remember it, it looks the same except that the shackles don't wrap under the frame rails like the stock ones do. It did give a little bit of ride height adjustment (maybe 1" or so, not much). Now that I think on it, might be a good idea to check to see if we used grade 8 bolts for those shackles. I don't remember
Old Sep 24, 2012 | 10:37 PM
effie_man's Avatar
effie_man
If he wants a cheap way to improve the ride and stance an old skool way is to take your spring pack apart. Keep the two shortest leaves and then remove every second leaf and put the stack back together. Good idea to do the bushings while the pack is out. It'll soften the ride and lower the back end about 2"
Old Sep 24, 2012 | 10:56 PM
Fomoko1's Avatar
Fomoko1
I like the extra pivot points, I think it was called something like knee action and agree that fewer springs will improve the ride. I don`t know exactly what my ride will be like but I`m willing to bet that it`ll be alot better than the original.
Old Sep 25, 2012 | 08:18 AM
yamagrant's Avatar
yamagrant
My original's are toast, half of the leaves are broken on the pass side. On the front I used a reversed eye main leaf and removed a couple more. With the road's here it should look and ride fine. Thanks guy's
greenmachine55
May 18, 2016 12:01 PM
robe
Feb 23, 2011 11:18 PM
Kurt G.
16
Jul 16, 2007 12:59 PM
ZZMAXX25
16
Jul 12, 2005 04:31 PM
fatfenders
Apr 24, 2002 06:42 PM
