97 F150 Won't Fire
Old Sep 10, 2012 | 05:48 PM
Truckmageddon's Avatar
Truckmageddon
97 F150 Won't Fire
Can the GEM module cause no juice to the coil pack? I have checked every fuse and relay on the truck! PLUS changed the ECM (or main computer) at the RH kick panel. Any ideas or comments will be greatly appreciated.
Old Sep 10, 2012 | 10:12 PM
critterf1's Avatar
critterf1
Wrong section.
Old Sep 10, 2012 | 10:36 PM
Truckmageddon
Thanks
Yep I realized that as soon as I checked my post. My brain did punch on the 97 section but the hand and mouse missed it.
Great forum.
Old Sep 14, 2012 | 08:42 PM
Papa Tiger's Avatar
Papa Tiger
Do you have any codes? No power means power isn't getting from the ECU to the coil. Look for a broken wire/bad connector. Look for a bad wire at the ECU plug also. Test thru the circuit for the open spot. Your key turns on the relay. Swap out the relay with a good one. Relay turns on the ECU and so forth.
Old Sep 14, 2012 | 10:14 PM
Truckmageddon
Thanks PapaTiger,
The problem was a bad conn at the plug on firewall by the top RH side of engine. I went over and posted on the 97 up section and got a lot of advice. I had checked every fuse and relay multiple times and had it boiled down to the hot wire between the relay and coil pack. But didn't know it's route. Turns out you were right also! Lot of great folks on here. Thanks
Old Sep 15, 2012 | 12:28 PM
Papa Tiger's Avatar
Papa Tiger
Those pesky connections!
roots4thought
May 19, 2016 01:59 PM
86Stepside
18
Jun 4, 2015 08:31 PM
bkrfrmhell
Sep 8, 2007 09:09 PM
donald campion
Jan 2, 2005 11:48 PM
cyberbyrd
Electrical Systems/Wiring
Mar 7, 2002 09:00 AM
