Sponsored by: Auxito
Bogging from D to R to D
Old Aug 13, 2012 | 11:56 AM
04mudslinger's Avatar
04mudslinger
With a warm engine in my 2000 with 5.4, the rpm's will drop to 4-500 rpm when going from drive to reverse and back to drive, like pulling out of a parking spot. At 219,000, I've not experienced it in the past it seems. Does this have something to do with the tranny engaging and bogging the engine? Or am I crazy and this is normal?
Old Aug 13, 2012 | 12:05 PM
04mudslinger
Clarification, rpm's drop when gears change and then rebound. Throttle body has been cleaned. I've swapped back from a CAI to the stock airway with a dry flow AEM filter.
Old Aug 13, 2012 | 12:55 PM
Bluegrass 7's Avatar
Bluegrass 7
The IAC is supposed to account for load from the torque converter.
Did you clean or replace it?
The drop to 500 rpm tells me it's not working.
Good luck.
Old Aug 13, 2012 | 02:36 PM
04mudslinger
I did replace it during the cleaning with a motorcraft one.
Old Aug 13, 2012 | 04:14 PM
04mudslinger
I agree bluegrass. The idle rpms don't increase due to air conditioning load either. The idle speed is the same with ac on or off. The connection to the iac is good, so maybe a bad one?
Old Aug 13, 2012 | 06:03 PM
Big_redneck3100's Avatar
Big_redneck3100
Your idle should stay about the same with A/C on or off. Its the IAC's function to control and maintain idle rpm with any given load on the engine. The exception being when idling in gear. My 99 F-150 with a 5.4L drops to about 500 to 525 when I put it in drive or reverse, and return to the 700+- when I put it back in park. It (IAC) still tries to stabilize the rpm, but I think it is just set a little lower in the PCM tables when in gear.
Tony Buscemi
2004 - 2008 F150
25
Dec 6, 2018 09:40 AM
1999-F150
1997 - 2003 F150
Jul 13, 2018 06:27 PM
supercrewser1751
1997 - 2003 F150
Feb 4, 2014 02:04 PM
Gerby Dutchy
2009 - 2014 F150
Oct 29, 2013 01:44 PM
BURNSTOUGHFORD
1997 - 2003 F150
Feb 17, 2009 01:58 PM
