When towing up a hill fo example and you have the truck at WOT. Does this put the engine under a great deal of stress? It only spinning 2800 rpm but the throttle is wide open. Should I just back off the throttle and take it easy or does it really matter. I know this is a stupid question and in think I know the answer to it, but I just wanted your input. Thanks
These modern engines love reving up high, you can be at the rev limiter all day and no harm will be done. Ive been loaded way past the maximum tow rating at 4k rpm going up an 8% grade for 8 miles my truck had at the time 280k it now has 302k and still going strong. Just make sute your cooling system is working properly as well as the fan clutch and you will be alright. Also a large transmission cooler will keep your tranny happy.
The way I read your post, your loaded heavy, the hill is steep and the rpm is down to 2800 rpm in the only gear that will allow the motor to make enough Torque to pull the load.
At 2800 rpm your not yet to max torque around 3200 so it only gets worse.
If this is correct, guess what is taking punishment?
The transmission CONVERTER. Same as standing still with the brakes applied on full throttle...
Done to many times, the converter can Balloon, break up the Torrington bearing, pump the pieces through the trans then you need a complete rebuild including a new Converter.
If you have it rebuilt stock and go do it again, the same thing can happen all over again.
The stock converters are not very tough under this kind of loading.
Ask me how I know?
A stock 4.6L has enough torque to do this if running without any faults.
I run a custom rebuild.
If the above is not what your doing, disregard it.
Ask me how I know?
I am running it out of overdrive at around 60 mph. I am guessing at the rpm.
With a 3.55 rear gear, 60 mph in third won't be 2800 rpm.
More like 2000 or less depending on the speedo accuracy.
Two things:
A. If you lock out OD, the trans will go into converter lockup, a good thing.
B. If a down shift occurs and you don't lock out the OD, the converter does not lock up and will heat the fluid more from converter fluid shearing due to slip and lose a little fuel mileage.
Two things:
Why are we playing this game and you not give all the info in the first post?
Calculate the engine rpm, the road speed using the info you already know.
In OD and third gear.
Consider tire diameter and whether the speedo is accurate if you changed rear gear ratio and not corrected the odometer reading.
All were doing is wasting time and can't offer any accuracy this way.
