Oil smell in cab when towing heavy
Old Jun 6, 2012 | 08:16 AM
TexasA&M's Avatar
TexasA&M
The last several times I've pulled my travel trailer (10k lbs), I've noticed a strange smell in the cab. It smells like motor oil, and it is only noticeable after towing on the highway for a while, and then coming to a stop. Once I start moving again, it goes away. It happens after 5 miles, and after 100 miles. Any time I come to a stop, I can smell oil (A/C on, windows up). When I get out of the truck though, the smell goes away. I can't find it under the hood, under the truck, or anywhere else. I also don't notice the problem when driving unloaded.
I don't have any leaks that I can find, so I'm kind of at a loss as to what is going on.
Any thoughts?
Old Jun 6, 2012 | 09:18 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Gonna be a small oil leak somewhere. You didn't mention using any oil so it may not be making a mess. The only thing I can think of to explain it only happening while towing would be the Crank Case Ventilation system. The engine can huff more under load and the CCV dumps the fumes in the intake tube on the drivers side. Might want to pull CAC tubing and check around that area. There is a write up in the tech folder for modifying the CCV system to help reduce the oily mess. If it's just a minor annoyance, running the a/c in recirculation mode will reuse air from the cab instead of pulling in new air from the cowl vents (where the oil smell is collecting).
Old Jun 6, 2012 | 09:29 AM
TexasA&M's Avatar
TexasA&M
It's not using any oil, or leaving any on the ground. Also can't see any residue from under the truck. There could be a small leak somewhere that is drying before it gets to the bottom of the engine though.
I hadn't thought of the CCV causing it. I've been thinking of doing the re-route mod for a while and make use this as an excuse to pull the trigger.
Old Jun 6, 2012 | 10:40 AM
lakewood's Avatar
lakewood
Any thoughts?
My truck does the same thing
Old Jun 6, 2012 | 10:45 AM
steelhead2's Avatar
steelhead2
Check the fitting that routes the ccv into the intake. You may have an o ring leaking.
2005Dually
Feb 9, 2010 07:22 PM
Toyhauler5
Jun 19, 2009 07:04 AM
jhand124
18
Aug 1, 2008 08:16 PM
John Kiernan
Mar 14, 2008 06:29 PM
Fordbronco69
Jan 18, 2007 08:40 AM
