none I am aware of are bolt in I just put a Pre 2003 crown Vic rear in my truck and after cutting the coil stuff off it's as simple as putting the leaf pads on I am even using the sway bar
How strong is the Vic rear end? where did you get one?
Thank you for the information
No, not really- unless maybe you're driving through a lot of water, or in the mountains.
The stopping power of the drums is perfectly fine.
If you've got a functioning 9" back there now, I wouldn't mess with it.
I have the donor to put disk on the front. ithink i will leave the back alone? I have a 74 F100 do you know if the power brakes and steering will work in the 65 F100
If you switched the front to a crown vic suspension, then your bolt pattern would be the 5x4.5 pattern like the explorer 8.8 rear. It's what I'm doing. Just picked up a cv front today and it only had 10,000 miles on it. $200 for it
