Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Big Job Number Help
Old Mar 8, 2012 | 11:02 PM
OldBlueOvalDude's Avatar
OldBlueOvalDude
Big Job Number Help
Am looking at a 57 T700 Big Job. Can't tell for sure if the first VIN digit is a 1, I, or T, am assuming it is T. Anyway, VIN is T(?)70N7U34982, date 22F, trans U, axle 16, GVW 28000, 172hp @ 3600, DSO 440202. Exactly what Y block did these things have? How hard is it to find brake parts? Thank you in advance!
Old Mar 28, 2012 | 12:18 PM
wmjoe1953's Avatar
wmjoe1953
Yes, it's "t". T70 equals T-700. '57 should be either a 272 HD for 700, and smaller, or could be when they went to the large motors. In that case, it should be either a 302, or 332 Lincoln Y-block. Most brake parts can be had from NAPA.
Old Mar 29, 2012 | 07:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
VIN is T70N7U34982, date 22F, trans U, axle 16, GVW 28000, 172 hp @ 3600, DSO 440202. Exactly what Y block did these things have? How hard is it to find brake parts? Thank you in advance!
T70 = T700.
N = 302 Lincoln derived Y block. This is not the same engine as used in a Lincoln.
7 = 1957.
U = Louisville KY Assembly Plant.
34982 = 1957 Numerical Sequence of Assembly, the trucks specific serial number.
22F = Assembled June 22, 1957.
U = With a 302 = Clark model 250-V3 5 Speed Direct.
16 = Eaton model 28MR Rear Axle / 7.79-1 / 28,000 lbs. Rear Axle Capacity.
440202:
44 = Twin Cities MN Ford District Sales Office, where the original selling dealer ordered the truck from.
0202 = Domestic Special Order number. The truck was ordered special by the original purchaser, not "bought off the lot."
You may have trouble finding original wheel cylinders. I may be able to locate NOS originals, other brake parts that NAPA will not have.
Get the parts cluck at NAPA to look in their paper parts catalogs, as I doubt any of these parts will be listed on their computer.
Old Apr 8, 2012 | 10:33 PM
OldBlueOvalDude
Thanks guys. As always, Bill, your decode is so detailed. Unfortunately the truck was up for silent auction and my low ball bid was much to low. Too bad, it would have made a real neat work truck. Hope the successful bidder wasn't a scrapper.
Old Apr 9, 2012 | 09:37 PM
alfm's Avatar
alfm
Hey NumberDummy,I need ppl like you to advise me where to access parts for older Fords.And btw I know a couple ppl retired from the Ford Truck plant in Louisville as thats where I grew up.Did you happen to retire from there or CA?
roy68
18
Jun 7, 2018 08:13 AM
rchalmers3
Large Truck
Apr 15, 2015 08:43 AM
real550A
Large Truck
Oct 19, 2012 08:57 PM
stockcar1974
Feb 6, 2010 10:23 AM
alexbubernak
Jul 14, 2007 10:02 AM
