JL AUDIO STEREO
Old Feb 16, 2012 | 04:24 PM
yendor0801's Avatar
yendor0801
JL AUDIO STEREO
i put in high end JL Audio system in my 2012 truck and everytime i turn the heat on in the seats it causes a buzzing sound in the speakers. Anyone out there have this problem..
Old Feb 16, 2012 | 05:34 PM
Cold One's Avatar
Cold One
It sounds like you need to relocate the ground wire. Did you ground it by the seats? Find a big bolt on the floor, take it out, remove the paint to bare metal, install a ground lug reinstall the bolt and dab some paint over the exposed metal to prevent rust. You may also need a bigger and/or shorter ground wire. Amps are very sensitive to ground noise. If posible do not ground it by the seats. What size is the amp and what size power and ground wire do you have? Hope this helps as always a pic of the wiring and install makes it better to trouble shoot.
Old Feb 19, 2012 | 05:19 PM
2011screw's Avatar
2011screw
I have the same thing. My ground wire is under the back seat. This is not my first time doing a ground wire for install of a stereo system so I am sure it is fine. I have put them in for 20 years. First time I have had a buzzing sound for heated seats though. I am going to wait until spring to check it out though.
Did you keep the factory stereo? I did. This is my set up
Stock DVD Nav.
Alpine PDX 4 channel amp
Alpine PDX mono amp
Audio Control LC6i Line Out converter
2 Boston 10" subwoofers
Alpine SPR-17S components speakers
If you figure it out, let me know
f-250.4x4.390
Jun 22, 2018 07:06 AM
lariat97
22
Apr 21, 2010 02:31 PM
1957F100
May 24, 2008 06:16 PM
kingz489
May 13, 2006 09:35 PM
SirDino
Jun 19, 2003 10:32 PM
