1998 expidition Blinkers
Old Jan 8, 2012 | 10:18 AM
silvman36's Avatar
silvman36
I have a 1998 Expidition Eddie Bauer edition and my front drivers side blinker in the front does not blink. Put new bulb in and still not working. Does any body have any wiring diagrams or any answers. Thanks.
Old Jan 8, 2012 | 03:04 PM
ecam8000's Avatar
ecam8000
Does the indicator in the dash and the rear lamp flash? Can you test the front socket with a test light or volt meter? I could be as simple as a bad replacement bulb or corroded contacts in socket. Could be a bad ground or break in wiring. Turn signal switches can go bad. In the old days, turn signal switches had "cat wiskers" that made various contacts when the lever was moved. I assume newer switches have a similar style (haven't replaced a newer turn signal switch, yet). Check the socket and let us know, we'll try to help.
Old Jan 9, 2012 | 08:18 AM
c_hohensee's Avatar
c_hohensee
Highly likely it is the multi-function switch. That is the turn signal stalk assembly.
Old Jan 24, 2013 | 06:05 PM
silvman36's Avatar
silvman36
tried the socket and that was not it. tore apart the multiswitch today and cleaned it all up and took a wire brush with my dremmel tool and that did not work eather. now my theft light is flashing and I can not start up my truck. any ideas?
Old Jan 25, 2013 | 02:31 AM
alloro's Avatar
alloro
You might've damaged the antenna 2-wire coil in the ignition switch.
Old Jan 25, 2013 | 02:34 PM
silvman36's Avatar
silvman36
I found that the ring around the key had three wires that were pulled out so I soldered them back and put new silicone on them. hopping this works.
Old Jan 25, 2013 | 06:04 PM
alloro's Avatar
alloro
out so I soldered them back and put new silicone on them. hoping this works.
If it works, I suggest you run down and buy a lottery ticket while your luck is running high!
Old Mar 6, 2013 | 01:20 PM
silvman36's Avatar
silvman36
ok still trying to get this blinkers fixed I have taken the multiswitch apart and cleaned every thing up in side and found the wiring for the blinker pigtail on the switch. still have no blinkers or hazards. now i have another question my diagram says the w/r is all time power but it only has power when the key is on. Also I have a factory tow package will this have any effect.
Old Mar 6, 2013 | 09:30 PM
pdqford's Avatar
pdqford
+ 1
And does the left front blink when the hazards are on?
Old Jan 3, 2014 | 11:24 PM
silvman36's Avatar
silvman36
Ok sorry you all about taking so long getting back but I got my blinkers fixed. I evidently blew the fuse for them wile working on them. And for the key switch it did work and has been working fine ever since.
Now I have a question I hope someone has the answer to. It is a general question. Can anybody tell me why oil burns blue when it comes out the exhaust and not black?
Old Jan 4, 2014 | 11:17 AM
alloro's Avatar
alloro
I pretty sure it's the additives in the oil that are burning blue and not the oil itself. Think of diesel fuel that doesn't have the additives that motor oil does and it burns black.
Old Jan 15, 2014 | 04:51 PM
silvman36's Avatar
silvman36
OK noe have a new problem. Went to store this morning and had no problems. When out about 30 min. Later to work on brake lights and now the theft light is flashing and can't start up my truck any ideas would be appreciated.
Old Jan 15, 2014 | 05:37 PM
alloro's Avatar
alloro
Got another key to try?
Old Jan 15, 2014 | 06:51 PM
Mark62's Avatar
Mark62
Was that RTV Silicone?
releases water and acetic acid as it cures....not good for electronics
Old Jan 15, 2014 | 11:05 PM
silvman36's Avatar
silvman36
No only have one key. Been working fine for over a year since I used the epoxy and have not had any problems till now.
