Feedback carb question
Old Nov 16, 2011 | 02:26 AM
kedwinh's Avatar
kedwinh
I was out tinkering with my truck today and noticed the chock wasn't opening all the way. It wasn't real bad but was sticking a little. So got the carb cleaner and sprayed around the chock and linkage area. Fix the sticking and it opens all the way now but while I was cleaning it I noticed that every time I sprayed the back of the chock housing it would almost die. I'm sure I wasn't getting enough in the carb to be causing it but couldn't see any vacuum lines or ports that could be causing it in that area. Any one have an idea what would cause this?
Old Nov 16, 2011 | 10:31 AM
f100jim's Avatar
f100jim
There is a passage from the inside of the choke housing into the manifold. This allows manifold vacuum to pull a little air through the hot air tube and across the bimetal spring in the choke housing. If your choke housing is cracked or is leaking, it will suck some of the carb cleaner into the manifold.
Old Nov 16, 2011 | 01:48 PM
kedwinh's Avatar
kedwinh
That makes sense. I had the chock housing loose to work and adjust the chock while I was spraying it. So maybe it got in that way, never tried it after I tightened it back up.
doctorolds
Jul 20, 2007 11:02 AM
farmnaggie
Apr 18, 2006 06:13 PM
paradochs
Jan 26, 2004 05:03 PM
Big Red
Dec 17, 2003 08:33 AM
